air vents
Old Oct 18, 2016 | 10:34 PM
littleriver's Avatar
air vents
Even with everything off I get a draft through the air vents on my 2015 EX. Is this normal?
Old Oct 18, 2016 | 11:16 PM
Fuelish's Avatar
If the selecter is set to fresh air, and not set to recirculate, then yes, this would be considered normal when the car is moving....
Old Oct 18, 2016 | 11:17 PM
ezone's Avatar
If fresh is selected, absolutely.
The body vents in the rear cause air to be pulled through the car while moving.
Old Oct 18, 2016 | 11:30 PM
tbFit's Avatar
Yes, and I like it that way... No fan needed. In my ST, it closes the vent when the fan is off. So the only way to have fresh air is to have the fan on low which is a waste. So I do prefer the Honda fresh air method because you can slide the vent to recirc to keep the air out when you drive through a dust cloud easily enough.
Old Oct 21, 2016 | 07:11 AM
bach's Avatar
I think the air flow is rather weak with fresh air and no fan, I was a bit disappointed that I had to engage the fan to get a little breeze going.
Old Oct 21, 2016 | 11:48 AM
Uncle Gary's Avatar
Yeah, there is a little air circulation with no fan, but, being a fresh air fiend, I always run the fan.
Old Oct 21, 2016 | 08:26 PM
tbFit's Avatar
Airflow increases substantially with the sunroof open without much additional noise compared to lowering the windows.
Old Oct 28, 2016 | 11:03 PM
The Fitness's Avatar
Thumbs up
That's true! Amazing how much of a difference the sunroof makes.
FitAK
Jan 24, 2018 07:47 AM
arkansasfit
May 14, 2014 03:27 PM
GTRPLYR
Jan 18, 2012 04:00 PM
Sherpa
Sep 2, 2010 03:48 PM
pmk
Jun 16, 2009 09:51 PM
