News: G&M | What’s the right way to stop at a red in a standard?
Old May 16, 2017 | 11:54 PM
TorontoBoy's Avatar
What?s the right way to stop at a red in a standard? - The Globe and Mail
An interesting discussion about how to approach a stop using a manual transmission. I leave it in gear 2 or 3 until the last minute, then simultaneously press the clutch and brake to a complete stop. At red traffic lights I'm in neutral with a keen eye on my rear view. If I see someone approaching from the rear too quickly I'll pop into 1st.
Old May 17, 2017 | 12:30 AM
Ryfle's Avatar
I come to a stop in 3rd/2nd gear if I know the light is about to turn green or if I'm stopping at a stop sign and I know I need to put it in 1st gear right away.
If I know I'll be at the light for a bit, I'll sometimes coast in neutral from about 30 mph or lower.
I also slow down in gear, but put it in neutral right before the car is coming to a complete stop -- I probably do this method the most.
Old May 17, 2017 | 10:11 AM
teamcheap's Avatar
I always coast to a stop if there's plenty of distance.
I don't even need to use the clutch, by timing it right, the stick will slip into neutral like butter.
Been doing this for 20 years...reduce wear-n-tear on tranny...get awesome MPG.
Old May 17, 2017 | 11:32 AM
2Rismo2's Avatar
Coming from motorcycling, it's always a good idea to be in gear when stopped at a light in the event you need to make a quick "getaway" from a driver not stopping. I stay in gear until the car behind comes to a stop at least. Nothing stopping the driver from being inattentive and running into me after coming to a stop though. That happened to me, but luckily I was in my pickup. Truck behind me got distracted and just started going while I was stopped. I was like WTF...
Old May 17, 2017 | 06:55 PM
depends on the car. some MT cars fuel cut at near 3k rpm where as some cars like just above 1.2k rpm. i use the fuel cut bump to get the car out of gear without using the clutch unless im approaching a stop quickly in my AWD car and prefer to disconnect the drivetrain as it can drag the car longer to stop. and this depend if im going down a hill, i might use 2nd gear to engine brake longer, etc.
just before the car stops completely i clutch-in and slide the shifter into the 1st gear gate without clutch-out. once stopped, im in neutral, clutch-out. this helps the shifter to go back into 1st gear as the collar is aligned for when the light turns green.
Old May 17, 2017 | 11:53 PM
4d3fect's Avatar
Depending on what (or who) is around me, I basically try to coast to a stop. Been consciously trying to improve my mileage bit by bit.
Old May 18, 2017 | 07:07 AM
the fuel cuts off when youre coasting so you're not wasting gas while coasting in gear...but you will coast farther in neutral, yes.
on my post above i shouldve posted when the fuel cut is bumped by the idle map(or watever it is) while slowing down i use that little bump in throttle the car applies on its own to get the car out of gear without the clutch.
Old May 19, 2017 | 10:41 AM
PaleMelanesian's Avatar
According to my Scangauge the Fit does fuel-cut engine braking down to 1200 rpm. You can feel the "bump" when it turns the fuel back on.
Old May 22, 2017 | 05:39 PM
Fuelish's Avatar
The right way ??? Don't stall it...
Old May 23, 2017 | 03:00 PM
fitchet's Avatar
Never Mind.
Romulus
Oct 6, 2010 10:34 PM
Fitcious
Jan 21, 2010 12:59 PM
Shockwave199
Jan 12, 2010 11:06 AM
vintagesierra
May 2, 2009 05:33 AM
fm2n
Aug 4, 2006 11:58 PM
