Bluetooth/USB Charger Conflict?
Old Jun 13, 2017 | 10:52 PM
dwjngs@gmail.com's Avatar
I have a 2015 EX, and for a long time my iPhone worked just fine when connected via Bluetooth and charging via USB. Whether or not the radio was on, or my iPod was playing (connected separately via USB), an incoming call would mute the music and come through.
About 6 months ago - it might have something to do with an iOS update - everything went sideways. Now, when a call comes through, the music mutes and I hear my phone ring, but when I click to receive the music comes blaring through. First thing I tried was selecting the audio input on the phone, but that didn't work. I eventually discovered that if I turn off the radio/audio and unplug the phone from the USB charger it functions like it used to - hands-free phone use.
Anyone else have an experience like this, or have any suggestions?
Thanks in advance!
Old Jun 14, 2017 | 07:23 AM
TorontoBoy's Avatar
Get a 12v USB charger. With the Fit your USB plug is also being used as an input device, thus confusing the Fit with two inputs. With the 12v USB charger this only provides power and cannot be used as an input device, thus solving the confusion. You'll also get a better, more powerful charge than the standard USB socket.
Old Jun 14, 2017 | 11:58 AM
Sorry, I forgot to include this - I had the same thought, and bought a 12v USB charger. No change in the phone's behavior. What I haven't tried yet, though, is a hard-wired 12v charger, something that goes straight from plug to lightning connector. That might be a good next step.
Thanks for your suggestion!
Old Jun 14, 2017 | 12:26 PM
TorontoBoy's Avatar
The 12v usb charger goes into the 12v outlet. There would be no difference between using the 12v charger and hard wired 12v charger. If the 12v usb charger does not work then there's no reason to try to hard wire one. You can get a 12v usb charger, then a usb to lightning cable for your Apple gear.
Old Jun 14, 2017 | 12:40 PM
Understood - that's what I've got now, a 12v charger with a USB cord running from it to my phone. Thanks for the heads-up about no difference between the outlet/hard-wired versions, though it looks like that rules out the charger as the issue...
Any other ideas about what might be going on?
Old Jun 14, 2017 | 01:56 PM
2Rismo2's Avatar
You could try deleting the Bluetooth connection from the car and your phone, then reconnecting it.
Old Jun 14, 2017 | 02:13 PM
Thanks, Rismo - I'll try that next.
Shipoffools
Mar 12, 2017 09:59 AM
poorracerkid
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
Nov 11, 2015 07:11 PM
nijkap
Dec 16, 2014 12:01 PM
Nortalud
Jul 5, 2011 03:43 PM
yer_daddy
May 11, 2009 05:54 PM
