P219A Code - wont go away!
Old Apr 23, 2018 | 04:48 PM
trolllalor's Avatar
Hi all,
I have a 2015 Fit Lx with 65k miles. Started getting check engine light around 55k miles. Got P219A code and ignored it because my performance and MPG was normal 35-40mpg. Needed to get an inspection and was busy so dropped it off at the mechanic (mistake!) was charged $600 - he did a valve adjustment, replaced ignition coils, inspected it. Code came back after 20-30 miles.
This weekend I took it apart myself and cleaned the fuel injectors and checked their resistance with a multimeter, they were all reading the same. Code was gone for 70 or so miles then came back this morning. What am I missing? Could it be an O2 sensor? I've googled, reddited, and searched this forum and I'm at a loss. Cant afford another mechanic bill like that. Would be appreciative for any insight and input !!!
Old Apr 23, 2018 | 05:41 PM
utsug's Avatar
Did a quick search and found this...
https://www.fitfreak.net/forums/3rd-...9a-code-2.html
Old Apr 23, 2018 | 06:07 PM
trolllalor's Avatar
thank you for that - I had read it previously but was wondering if there were other ideas since I think my injectors are in good condition.
Old Apr 23, 2018 | 08:43 PM
CommanderSlug's Avatar
My 2015 had the injectors and some part of the fuel line replaced under warranty at 16k miles... due to that pesky check engine light. I did not have fuel economy issues before or after the replacement. Everything was good all the way up to 81k miles ... when I traded the car in.
Youaretyping
Aug 6, 2024 01:19 PM
SilverEX15
Sep 7, 2018 03:59 PM
Gula
Feb 22, 2017 12:52 PM
markielowski
Jan 2, 2011 03:08 PM
madvibes
Aug 31, 2010 07:16 PM
