Megan Racing Lower Arm Bar (MRS-HA-1291)
So I recently picked up one of these:
Megan Racing Lower Arm Bar (MRS-HA-1291) Lower Arm Bar for Honda Fit 2015+ Install seemed straight forward, I imagined it would go down something like this: https://cimg5.ibsrv.net/gimg/www.fit...aa6570e7ca.jpg Well .... it didnt go so smooth. When I line up the front of the brace (narrow end) against the sub frame, it looks like this: (lines up good, but no where to stick bolts through) https://cimg0.ibsrv.net/gimg/www.fit...4b29be8a05.jpg (And the rear end/wider end does not line up as the hardrace bar does) https://cimg6.ibsrv.net/gimg/www.fit...816726a455.jpg (another shot slightly from further away) https://cimg5.ibsrv.net/gimg/www.fit...c1ffd3e802.jpg https://cimg4.ibsrv.net/gimg/www.fit...c90c110e98.jpg FWIW .... I was able to install their Front Lower Control Arms with success .... https://cimg0.ibsrv.net/gimg/www.fit...8cee888645.jpg https://cimg5.ibsrv.net/gimg/www.fit...5782268060.jpg https://cimg6.ibsrv.net/gimg/www.fit...e73ac22221.jpg |
UPDATE:
I provided my VIN plate on the drivers side door jamb. It would appear some early production 2015s have a subframe that does not fit the bar. Megan was very nice about the returns process, and I will be getting a refund soon. I'm a little sad |
Very interesting about the subframes. Sucks you ca't use the bar and I'm sure swapping subframes isn't worth it. What are you impressions about the other bar?
(Post 1402550)
UPDATE:
thad, other bar is nice, and the install was quick and painless. cant go wrong for $40 ish bucks. its not as much of a game changer as a front sway .... but again, for under $50 bucks tho.... I recommend it!
from what I was told ryu, later 2015s and up, are fine. I'm hoping someone 2016, 2017, and 2018 will buy a bar, and post pictures for us all to see. I did find a back up plan .... this Ultra Racing bar appears to mount without needing to touch the sub frame .... I'm 99% sure this will work.... I'm just not sure if I'm ready to pay 2x more ... as most of you all know, I'm cheap =) https://cimg7.ibsrv.net/gimg/www.fit...fd95881cc4.png blue line drawn, illustrates where the megan/hard race bar would have installed |
