Does the MTF drain plug use the same crush washers as the oil drain plug?
Old Mar 12, 2019 | 12:59 PM
Ogrelode's Avatar
I watched a video of a dude replacing the CVT fluid on his 2015 fit today, from the K.I.S.S. guide. I'd imagine the process is nearly identical for a manual transmission. He said to buy a replacement "gasket" for the fill plug. Does this mean the crush washer, and if so is it exactly the same one used for the oil drain plug, or is it different for the MTF fluid drain plug?
Old Mar 12, 2019 | 02:46 PM
CommanderSlug's Avatar
Yes, crush washer and yes, same as the one used for the engine oil drain plug. Note that the crush washer for the fill plug is larger in diameter, so in the end you need two crush washers in total, one smaller [same as engine oil drain] and the other one larger in diameter.
utsug
Sep 19, 2017 12:50 AM
down_corporal
Jan 26, 2017 08:16 PM
mmitsch
Oct 6, 2014 02:00 AM
rpboy06
Jun 21, 2008 03:34 AM
moates
Nov 11, 2007 06:56 PM
