Maintenance Minder - Main Code ONLY - NO Sub Code
Old Sep 13, 2019 | 05:55 PM
sumtingwong's Avatar
Hi All... Has anyone seen a maintenance minder with main code ONLY and with NO sub code! My "A" service has always come with a 1 (tire rotation). But earlier this week, my maintenance minder only shows an "A". There is no sub code? Is there anything wrong with my car or this is normal? Thanks!
Maintenance Minder showing main code A without the usually sub code 1
Old Sep 14, 2019 | 12:31 AM
woof's Avatar
"Replace just the Engine Oil"
Tsk. Tsk. You've allowed your oil life to drop right down to 5%. Perhaps Honda should change the message to read "Negligent owner should not have allowed oil life to drop to 5%".
Old Sep 14, 2019 | 02:52 PM
5% is nothing... i've run on negative miles before... BTW. Have you ever seen MM with just the main code and no sub code. I've owned 3 Fits and never seen anything l like this... This is so weird!
Old Sep 14, 2019 | 03:15 PM
hasdrubal's Avatar
I try to change the oil at 10% remaining, but I'd bet Honda left a large safety margin assuming some owners would procrastinate. Just like you can probably drive 30 miles after the range indicates zero, but I don't test that one either.
drkatherine1
Mar 27, 2017 09:52 PM
exl500
Jul 13, 2016 03:50 PM
Yummy Flaquito
Zeta Products.net
Jun 22, 2012 09:22 AM
markwalter
Mar 22, 2010 08:03 AM
