Sluggish acceleration
Old May 11, 2026 | 11:44 AM
Revo39564's Avatar
2015 Honda fit engine revs nicely at park. Car is bogged down/lacks power when accelerating until 20 mph or once it hits 1500-2000 rpm’s.
Checked timing chain and timing …both ok. One aftermarket new ignition coil was noted, all looked ok per multimeter. Replaced Autolite plugs due to misfire. Valves are clean, positions clean, valves adjusted ……Cleaned MAP sensor. Did fuel injector test via obd scanner and tested ok. Changed CVT fluid and it was black but no access metal shavings noted in magnets or filter. Cvt shifts fine once at higher speed and in reverse…..
Kiewiet
Apr 6, 2024 05:43 AM
Kimbo
Feb 12, 2024 06:09 AM
Eitan Benjamin Feldman
Oct 26, 2022 12:34 PM
szellmaniac
Jun 3, 2022 02:27 PM
Belch
Mar 4, 2022 07:50 PM
