Which FRAM Air Filter for 2015 Fit LX
Old Jun 3, 2015 | 03:59 AM
Namae Kana's Avatar
It's too new. The Fram catalog doesn't list the 2015 Fit.
Old Jun 3, 2015 | 09:31 AM
SLVR6's Avatar
I wouldn't waste your time on it then as Fram is not what it used to be. I use K&N air filters exclusively in all my cars. Never have to buy a new filter again, just clean it.
33-5027 - K&N Replacement Filters, Replacement Air Filter
Old Jun 3, 2015 | 02:21 PM
Namae Kana's Avatar
Fram CA10650
I believe the 2015 FIT uses the same Fram CA10650 Air Filter as the 2013 FIT. Please confirm.
Old Jun 3, 2015 | 04:22 PM
GeorgeL's Avatar
A lot of people swear by K&N filters, but be aware that they pass more fine particulates than disposable filters.
K&N made their reputation by making low-restriction filters for off-road racers. A car or bike equipped with K&N would continue to run where a dry filter would be clogged by fine particulates. This prevented DNFs and of course if you don't finish you don't win.
The downside was that the fine particulate did cause engine wear, but for racers who run a limited number of miles and rebuild engines frequently this was not an issue. The filter did trap the coarse particulates that could cause rapid engine failure. This made it an ideal filter for off-road racers.
Now, what does this mean for street drivers? Well, if you are a racer and want the best breathing possible the K&N might be worth a horsepower or two, but so would running no filter at all. If you want long engine life then a K&N might not be so good. Most modern vehicles operate in a very clean environment so they would be OK, but if you occasionally drive in dusty environments like dirt roads you really don't want a K&N in your car.
I love K&Ns in my race bikes, but I wouldn't run one in my cars. What is good for a racer isn't always good for a street driver.
In answer to the original question, why not buy a filter at the dealer? I've found that some dealers have OEM filters at the same price as Fram, et. al.
Old Jun 3, 2015 | 04:33 PM
Namae Kana's Avatar
I was looking online. I gather the 2015 FIT uses the same Fram CA10650 Air Filter as the 2013 FIT. is that the case?
Old Jun 3, 2015 | 08:40 PM
Uncle Gary's Avatar
No. I have a '15 Fit and a new filter for my '09. I've tried the filter from the '09 in the '15 and it's not even close to fitting. Totally different shape and size. Too bad, 'cause now I'm stuck with a filter and no car to put it in.
Old Jul 9, 2015 | 09:05 AM
Why2kmax's Avatar
Use a Honda filter, FRAM are junk.
Old Jul 9, 2015 | 12:21 PM
Namae Kana's Avatar
Do you know which FRAM air filter fits the 2015 Honda Fit LX CVT?
Old Jul 17, 2015 | 05:50 AM
Helistyle's Avatar
If you look on frams wesbite it says our cars take #7317 for the oil filter not sure for the air filter.
I have been using fram filters for years on multiple cars with now issues.
Old Jul 17, 2015 | 07:48 AM
Redd's Avatar
there's a reason Fram doesn't make any OEM filters, and as far as I know this is still the case...
Old Jul 17, 2015 | 12:03 PM
Namae Kana's Avatar
Great. So what's the part number for the air filter please?
Chitown Fit
Aug 7, 2020 11:36 PM
john21031
Apr 30, 2019 12:16 PM
Chitown Fit
Apr 7, 2019 01:52 AM
Colonel Panik
18
Dec 29, 2015 11:59 AM
alpine
May 27, 2014 01:36 PM
