Warning lights...all of them.
Old Jun 12, 2015 | 12:16 PM
ShadSlime's Avatar
Interesting thing happened a couple weeks ago. Went to start the car when I got off work, and got the TPMS, Check Engine, stability control, and steering assit warning lights all at the same time. I pretty much freaked, but had to go home since the dealership was closed for the day. Car acted just fine on the way home. Idles normally. Nothing out of the ordinary except the lights. one tire was a couple pounds low.
Decided to see if I could clear the code. Unplugged the pos battery cable for a minute. Except for having to reset the clock and setup my bluetooth pairings again...everything was great. Until today...when all the lights came on this morning. Same deal. Car acts just fine.
I really don't have the time to deal with leaving my only transportation at the dealer for them to "figure it out".
Ideas?
This is base model w/6spd
Old Jun 12, 2015 | 12:54 PM
Bronxborn's Avatar
Honestly, something like this I would just give in to the dealer and hope for a rental. No need to void any warranty if something is really wrong.
Old Jun 13, 2015 | 07:59 AM
frazzledglispa's Avatar
I had an issue with my Hyundai Accent years ago. The check engine light kept coming on. My Brother-in-Law came over, hooked up his computer to the car. We replaced the O2 sensor and the light went off.
Two weeks later it came on again
Disconnected/reconnected the battery, the light didn't come back on
I took it to the dealership and they hooked it up and told me it needed a new O2 sensor. I told them - that was just replaced.
After much investigation it was determined that relay that controlled the check engine light was bad, and was causing the light to come on, even though nothing was wrong.
You might have something similar going on, I would take it in.
Good luck!
Old Jun 13, 2015 | 09:11 AM
Evesowner's Avatar
Bring it to the dealership. And if you can't do that right away you might want to either get one of those OBD Bluetooth sensors and pair it your phone + OBD app to determine the problem according to the Fit's computer. Or save the $10-20 (cost of the OBD device) and just stop at an auto parts store and ask them to check the codes. Most of them do it for free. So you can find out how bad it might be before you have a chance to get to the dealer.
Regardless...I'd recommend everyone get one of those OBD devices. Their handy things for just a few bucks. With the right app you can even reset the computer without needing to disconnect the battery (which doesn't always work to clear the codes without significant wait).
Old Jun 13, 2015 | 12:08 PM
gkitf16's Avatar
OBD code reader
Got one off eBay a while back, very useful, esp if you're trying to chase a problem. Get Torque Pro from Google Play market, couple of bucks. I have an '09 Fit, just reach beneath the steering column to the right, forward of the driver's cupholder, plug in the adapter. The ECU displays quite a bit of data thru the app, but won't show 02 sensor data (weird). But everything else it can read is very valuable. If it finds any fault codes, it reads them out loud for you in plain english. Pretty cool.
Old Jun 17, 2015 | 09:25 AM
ShadSlime's Avatar
Took it to the dealer yesterday. Miss on #3. They replaced the coil, and plug. When I left he was going to check the valve lash. If it isn't the valve...its probably the injector. And of course with direct injection...you have to replace them as a set.
I'm sure they are looking for a way to weasel out of doing this as warranty knowing my luck.
Old Jun 17, 2015 | 11:17 AM
Colonel Panik's Avatar
Same problem, mine was caused my wires being chewed on by rodents.
Old Jun 17, 2015 | 11:22 AM
ShadSlime's Avatar
Intake valve on #3 is leaking oil bad. Bad head casting. CAn't get a new one until September.
"Hencho en Mexico"
Old Jun 17, 2015 | 02:02 PM
ShadSlime's Avatar
Found another thread where more people have this problem. Wondering at this point...what should I do?
Old Jun 18, 2015 | 09:21 AM
ShadSlime's Avatar
They have me in a rental car. Terrible mileage compared to my fit.
Talked to the service adviser yesterday. He claims to have never hear about anyone having this problem. I'm hoping to get some real failure information out of his as this goes on. Really not keen on the idea of replacing a defective part with another defective part...that might just barely last long enough to run out my warranty.
Has anyone heard anything about this? Is it just a bad batch, or did they screw up the design for the new head?
Old Jun 23, 2015 | 09:28 AM
ShadSlime's Avatar
They still have my car. I'm now under the impression that the service adviser is lying to me. He gets all shifty when I ask about what he thinks the problem is.
I wonder if calling Honda is a good idea?
Old Jul 9, 2015 | 09:35 AM
stellgod's Avatar
Did you ever get fixed?
Old Jul 9, 2015 | 09:48 AM
ShadSlime's Avatar
They still have my car, and I have not heard a peep out of them. Getting pretty pissed. At this point I am certain he was lying to me. There is no way that there is such a long lead time on a part they supposedly got authorization to pull from the assembly line.
Really worries me that there might be a design flaw from the head redesign...and they are trying to crank out a revised part...on the sly. Probably to avoid a recall.
Old Jul 9, 2015 | 02:06 PM
stellgod's Avatar
Your fast approaching the lemon law my friend. I'd check your local laws to make sure, but it sounds like a fat check is in your future.
Old Jul 9, 2015 | 02:13 PM
ShadSlime's Avatar
30 days within the first year. I'd take a 5,000mile hit to the worth of the vehicle.
Thing is...I love the Fit. I want my Fit to be reliable. If they screwed up the head, I want them to cop to it and revise the damned part. This is HONDA damnit...they know how to do this crap.
Old Jul 9, 2015 | 08:54 PM
Bronxborn's Avatar
I think it was just a bad batch. There are many othwers that have not run into this issue - meaning that even though initial design from Honda was excellent, there was still issues here and there in the production of parts.
The fit is a great vehicle and being a honda engine, you wouldnt expect such failure but it does happen - and its the rarest occurance with Honda.
You did run into some bad luck unfortunately, and I hope your issue can be reaolved without you taking any more losses besides a rental with poor gas mileage.
Old Jul 10, 2015 | 08:52 AM
ShadSlime's Avatar
Multiple people with intake valve failure on #3 makes it hard to believe that it was a QC error like bad casting. Also have to figure that only a VERY small percentage of fit owners would post a problem in a forum.
I hope I"m wrong...because I really like my Fit. If they replace the head, and it fails again at 80K when my warranty goes out? I'm gonna explode. lol
Old Jul 19, 2019 | 01:51 PM
Victoria T's Avatar
Check the battery
Weak voltage can cause it. Check to see if you need a new battery or if your battery posts are loose. The first time it happened to me, the cable was loose. The second time, I’m taking it to the dealer in a couple of days. It happened right after I had the oil changed, air filter changed, and cabin filter changed. I’m going to assume something wasn’t done correctly.
Old Jul 19, 2019 | 04:37 PM
evilchargerfan's Avatar
messing with the MAF will cause lights to light up
disconnect battery, and see if it goes away
(nice first post ... and 4 yr thread revival)
esnave09
May 7, 2023 07:04 PM
SilverEX15
Nov 1, 2017 04:25 PM
esnave09
Dec 21, 2016 01:28 AM
Goobers
Jan 9, 2012 02:32 PM
Goobers
Dec 27, 2011 08:51 PM
