Alternator ECU Bypass Charging System / Battery Sensor
Old Jul 21, 2020 | 07:45 PM
AstroPacillo's Avatar
Hey guys, I believe I have stumbled across the ECU bypass for the alternator charging system by accident.
I have a voltmeter hooked up to my cigarette lighter port, and noticed it would shift from 12v to 14v sporadically. After hours of research, I found there's a smart system that cuts the alternator on and off when demands are high or low to extend the life of the alternator. For many of us running an aftermarket audio system, we're struggling with the undersized alternator output and can't afford for the charging system to decide "low demand" and drop our alternator output randomly.
On your factory battery negative post, there is a small black battery sensor with a 3 wire connector. If you disconnect this and start the car, you will get an error code "Check Charge System"..... BUT you will be at a constant 14+ Volts! You can also pull the fuse for your battery sensor but it will also cut your DRL (daytime running lights) in the Gen. 3. It is either fuse #15 or #17, both 7.5 amp fuses.
I have been running my Fit this way for 6+ weeks with no issues yet. I purchased a shunt and an ammeter to read my amperage draw on my charging system with the battery sensor connected vs. disconnected. I'll post results when I set everything up.
I will also be upgrading my alternator to a 280 amp output in the upcoming weeks. I'll post a new thread once it's complete hoping the ECU bypass allows me to pull more than 100 amps LOL.
Old Jul 26, 2020 | 06:59 PM
James Butler's Avatar
Thanks for the information.
You are correct the Honda system looks at the battery voltage and the current draw on the system all the time. When battery voltage is high enough and demands are low the computer turns off the alternator to allow it to free wheel and help save on gas. I installed a voltmeter on my 2015 Fit and watched this in operation. The first time it happened I thought alternator went bad. It went from 14.2 volts down to 12.7 volts which was battery voltage without alternator working. I ran for 20 miles while the battery voltage went down to 12.4 volts before the charger came back on. cruising down the road with charged battery and low load will turn off alternator ouput. If I want to turn alternator back on just turn up radio , turn on lights, or AC compressor to draw more from battery and the ECU will turn it back on and voltage will bt 14.0 volts charging. If the ECU does not have information from sensor it will put charger message on screen and run alternator constantly to keep battery charged.
Did you remove the black sensor from the car or just unplug connector?
Looking forward to your charging information charts.
James
AstroPacillo
Sep 8, 2020 11:01 PM
AstroPacillo
Fit I.C.E.
Jul 21, 2020 07:45 PM
13fit
Oct 8, 2014 11:31 AM
MrStix
Oct 22, 2011 04:26 PM
