Where to buy? Nav Headunit
Old Feb 26, 2015 | 11:43 AM
Stapleface's Avatar
As the title says, I'm curious if anyone has been able to find out any info about the Nav headunit in the GK. I've done quite a bit of searching and can't find anywhere to purchase the OEM unit. I KNOW it would be expensive, but that's not the point. And if you wanted Nav you could have just gotten the higher trim. That's not the point either. I actually don't want leather and Honda doesn't offer the Nav headunit as a stand-alone option. I don't even know if this shows up in Honda's parts catalog. So, short of keeping an eye on the f/s section, anyone know of a place to source this head unit?
Old Feb 26, 2015 | 06:26 PM
Fitmo's Avatar
Bernardi Honda Parts discounted prices below. You'll have to remove the headliner, and some of the plastic pieces in the vehicle, and disassemble the dash. I'm not sure if you wouldn't need other wiring harness replacements.
Base, Antenna 39152-T5R-A11 $47.16
Feeder Assy., Roof 39160-T5R-A31 $18.47
Sub Feeder, 39156-T5R-A11 $14.61
XM Unit, 39820-T5R-A01 $182.33
AUDIO UNIT, DISPLAY (WITH MAP)(MITSUBISHI), 39100-T5R-A61 $2,965.08 (lists for $4,223.77)
ANTENNA ASSY., GPS 39835-T5R-A01 $20.51
Edit: If you want XM and Navi, it would be cheaper to buy the EX-L Navi and put cloth seat covers on it. You'd also get heated outside mirrors with turn signals on them, as well as leather steering wheel and shifter.
Old Feb 26, 2015 | 07:00 PM
Stapleface's Avatar
Wow, thanks for the info. That's unfortunate. Coming from the Subaru world those are some eye popping numbers. A lot of their stuff is cross compatible without much needed to make something else work. I assumed (wrong of course) that it would be a simple matter of swapping head units. Guess not.
Old Feb 26, 2015 | 07:12 PM
Fitmo's Avatar
No. The rear antenna base has to be swapped with one that also has an XM antenna in it, meaning the wiring that goes across the roof is different, and there's a GPS antenna in the middle of the dash.
Edit: even if you bought all these parts, it still may not work because these radios are tied to a VIN.
Old May 11, 2017 | 08:58 AM
Israel Mendoza Alcantara's Avatar
Question about mods
[CITA = FITMO; 1294354] No. La base de la antena trasera tiene que ser intercambiado con uno que también tiene una antena XM en ella, es decir, el cableado que va a través del techo es diferente, y hay una antena GPS en el centro del tablero.
Editar:. Incluso si usted compró todas estas partes, todavía no puede trabajar debido a que estas radios están atados a un VIN [/ quote]
hello FITMO
I bought a radio on ebay with touchscreen, when I installed it works perfectly in terms of physical cusetion and tuning (I was given the serial number of the car and I was able to recover the lock code from the Honda page)
However I can not modify the time nor connect via bluetooth because it says that the car is in motion.
I have a Honda Fit 2017 version FUN in which had the stereo without color screen, buy the next version with color screen and knobs to a local seller here in Mexico having the same problem with Bluetooth, frankly I did not give importance because I had Thought to buy one with touchscreen, but now that I have it has the same problem.
Can be by the association of which you speak ????
How can I do to reset as if it were linked to my VIN?
thank you very much.
09blackfit
Jan 19, 2009 05:04 PM
pwnstar
Dec 7, 2008 01:30 PM
DrKelso
Oct 8, 2008 09:51 PM
karprive
Sep 15, 2008 09:52 PM
fit4kris
Jun 22, 2007 11:10 PM
