3rd Generation GK Specific Suspension & Brakes Sub-Forum Threads discussing suspension and brake related modifications for the 3rd generation Honda Fit (GK)
NEW GK5 front A-Arms by Art of Speed Racing
Old Mar 22, 2019 | 05:53 AM
CarbonTek's Avatar
We've got a revised and updated tubular chromoly A-arm currently in testing. Should offer improved turning radius over our v.1 racing arms
Old Mar 25, 2019 | 01:05 PM
CarbonTek's Avatar
Old Mar 28, 2019 | 02:19 AM
TougeMonster_GK5's Avatar
How can we order? Group buy deal??
Old Oct 22, 2019 | 04:22 PM
Deemmachine's Avatar
Any update on these?
Old Oct 26, 2019 | 06:40 PM
elkaku's Avatar
How or where can we get ahold of this!!!!!
Old Feb 8, 2021 | 03:37 PM
Cndctrdj's Avatar
Those look killer. Any idea when they will be available
Old Feb 9, 2021 | 12:35 PM
NWCH's Avatar
Beautiful work!
Old Mar 22, 2021 | 12:18 AM
slimchriz's Avatar
https://asr-motorsport.com/shop/
company sells one product only though?
Old Oct 30, 2021 | 01:02 AM
JingJangJoe's Avatar
It doesn't come with the necessary bushings?
Old Oct 31, 2021 | 07:51 PM
MasterKwan's Avatar
These arms don't use bushings. Looks like spherical bearings instead.
Old Nov 4, 2021 | 04:05 PM
DannyJ7's Avatar
$550?! That's nuts.
Old May 28, 2022 | 02:20 PM
Z062FIT's Avatar
Just purchased
Can't wait to get these in the fit. They widen the track 1/2" to 3/4" if I remember correctly. I'll be getting upgraded axles for power and will adjust length accordingly. Has anyone heard of an equal length half shaft mod for the GK5?
Old May 28, 2022 | 11:37 PM
Equal length drive shafts are not possible unless you change your gearbox.
Old Jun 8, 2022 | 09:23 PM
CarbonTek's Avatar
Guys, as I left China and am no longer affiliated with the team, direct all inquires to Joe@asr-motorsport.com
he tells me that they have them in stock and ready to ship.
Old Jun 9, 2022 | 11:02 AM
Z062FIT's Avatar
From a DSM website: Using Equal Lenth Half Shafts on a FWD is supposed to reduce torque steer and wheel hop while improving handling and traction, especially during cornering. Swapping to Equal Length Half Shafts involves installing an AWD driver's side axle and intermediate shaft on a FWD DSM. This will only work on 1990 - late 1992 FWD DSMs. Starting in late 1992 the FWD's used a bigger spline shaft that goes into the transmission. The AWD splines are the same size from 1990-1999 and match the 1990-1992 FWD splines.
I was hoping to build an intermediate shaft that would come out the STOCK transmission, and then go equal length from there. Would be something that would mount to the rear of the block. Basically, torque should be the same as long as the shaft is perpendicular to the source. So the intermediate shaft is parallel to the exit from the differential. Then two equal length axles could connect, eliminating a lot of torque steer...
@CarbonTek Thanks for the update! I put in my order and they said they are making them and once built, they'll be shipped. Cheers! Good luck in Canada!
Old Jun 10, 2022 | 03:54 PM
RD36's Avatar
Originally Posted by DannyJ7
$550?! That's nuts.
It's now 850
Linksy
Oct 30, 2023 01:21 AM
CarbonTek
Feb 4, 2019 12:54 PM
bosho.777
17
May 17, 2018 10:19 PM
1stVR6
40
Feb 12, 2017 05:57 PM
SpoonFitGD3
Oct 21, 2008 10:25 AM
