3rd Generation GK Specific Suspension & Brakes Sub-Forum Threads discussing suspension and brake related modifications for the 3rd generation Honda Fit (GK)
!!!!! Finally my GK5 Lowered !!!!!
Old Sep 24, 2014 | 01:39 PM
bbigmouthh's Avatar
Talking !!!!! Finally my GK5 Lowered !!!!!
Old Sep 24, 2014 | 01:57 PM
TofuShop's Avatar
Looks so much better lowered. Grats
Old Sep 24, 2014 | 01:58 PM
Waiz's Avatar
Avid FitFreak Poster
Looking good, now for some wheels
Old Sep 24, 2014 | 02:29 PM
painterguy's Avatar
Senior Member
looks great.
Old Sep 24, 2014 | 02:42 PM
Qbrozen's Avatar
so the previous gen springs fit the '15? That's interesting. Should mean that the same would be true of all the manufacturers, yeah?
Old Sep 24, 2014 | 03:19 PM
GTtoGK's Avatar
Bbig -Wow, that looks awesome! Just curious, on another post you show a pic of the Tein box with part# SKB74-S1B00 on it and the pic above it shows part# SKB74-AUB00.
Just to clarify, part # SKB74-AUB00 are the springs you installed? As Qbrozen mentioned, GE8 springs will fit on the GK5.
Regardless, your car looks great man!
Old Sep 24, 2014 | 03:21 PM
bbigmouthh's Avatar
In Japan GP5 GK3 GE6 GE8 they used this one.
Old Sep 24, 2014 | 03:27 PM
bbigmouthh's Avatar
Yep,The one I installed is SKB74 AUB00 . GE and GK use same Springs.
Old Sep 24, 2014 | 03:42 PM
noripwr's Avatar
That looks sweet bbigmouthh. You got wheel spacers on too correct?
Old Sep 24, 2014 | 03:49 PM
bbigmouthh's Avatar
Yep, 25mm is nearly flush,I love that
Old Sep 24, 2014 | 06:26 PM
op420's Avatar
Alignment
Looking great man!!! Just curious if you were able to adjust the front camber to specs with that kit? Any rubbing on hard bumps?
Old Sep 24, 2014 | 07:37 PM
noripwr's Avatar
High 5 for the PBP crowd. The GK Fit looks really really good lowered. I second the question above. Any rubbing with the car lowered now?
Old Sep 24, 2014 | 07:46 PM
FittinglyFittedFit's Avatar
Looks dope! Loving the new models and that color is cool!
Old Sep 24, 2014 | 08:36 PM
JN2k108's Avatar
If the springs fit, would the shocks fit too?
Old Sep 24, 2014 | 11:26 PM
bbigmouthh's Avatar
Thank you,
No camber adjust with no rubbing at all
Old Sep 24, 2014 | 11:43 PM
superfanatico's Avatar
Looks great dude!!
Old Sep 26, 2014 | 02:42 PM
ashchuckton's Avatar
Looks nice, I'm wondering how much your alignment changed. If it did can you get the numbers back to where they should be. Added negative camber will benefit your handling to the detriment of tire wear. What would concern me is, did the toe change by adding toe in or toe out because of the lowering?
Old Sep 26, 2014 | 03:26 PM
abrunson7's Avatar
Dat color!
Old Sep 26, 2014 | 04:01 PM
bbigmouthh's Avatar
I not alignment yet just let spring sit a bit,also i believe you no need to add negative camber I have no rubbing issue too.
Old Sep 26, 2014 | 04:56 PM
I don't think you need to add negative camber or it adjust it at all. You probably should get to an alignment shop sooner than later. If adding the camber gave your Fit more toe in you will eat those tires pretty quickly.
