205/50/16 vs 205/55/16
Old Mar 19, 2017 | 10:09 AM
bigbacon's Avatar
I assume there is zero difference here in a 50 vs 55 except maybe an ever so slightly less harsh ride?
Old Mar 19, 2017 | 12:15 PM
ezone's Avatar
That's gonna be .8 inch taller and therefore almost 3-1/4% speedometer error change to the slow side (you will be traveling faster than the speedometer says), along with similar odometer error and a slight reduction in calculated gas mileage.
863 Revs/Mile vs. 835 Revs/Mile
https://tiresize.com/calculator/
Old Mar 19, 2017 | 12:28 PM
bigbacon's Avatar
well figuring OEMs are already 55s i'm not sure what you are getting at.
Old Mar 19, 2017 | 01:09 PM
ezone's Avatar
Aw dang, I didn't even think of stock size. And none came with tires 205 wide either.
185-55-16 was probably the stock size? 205 tires on that wheel width might look like little balloons, but doable.
Going from 185-55-16 to 205-50-16 the speedo calculation difference would be negligible, but since more tire contacting the ground there would be a bit harsher ride.
The 205-55-16 would be taller of course
Old Mar 19, 2017 | 07:49 PM
Rob H's Avatar
205/50R16 and stock 185/55R16 are virtually the same not counting differences in tire manufacturers. I use this free online tool allot
Online Wheel and Tyre Fitment Calculator. Offset, Tyre Stretch and Speedo Error | Will They Fit
silentnoise713
Jun 7, 2014 09:40 PM
Nio4
Jul 2, 2013 10:45 PM
AtticusFit
Oct 11, 2012 10:16 AM
Santiad
Oct 23, 2011 09:01 PM
Spacecoast
Jun 30, 2011 12:02 AM
