Honda fit 1.5 vtec low rpm and hesitation
My honda fit 1.5 sport 2007 just started vibrating and shaking when releasing brake pedal it need 2 sec to start moving and rpm drops nearly at 0 and tachometer needle always moves up and down . Acceleration is realy slow . Yestarday i changed all 4 coils , they were burned from electricity. Bought new ones but problem got worse . Spark plugs are new and has no problem. Need help. OBD did not find any faulty codes
Last edited by Erekle Eremeishvili; Mar 4, 2019 at 03:13 PM. Reason: I missed 1 problem that my car has
I had the a similar issue, but with an 08 Fit. A valve adjustment did the trick, though I also replaced the spark plugs since I had to remove them anyways. I don't know where on the site it is anymore but there is a good tutorial to follow if you don't mind opening your engine head.
Missfire
Feb 1, 2020 02:53 PM
bengee
Oct 13, 2019 01:14 PM
SAPD
Apr 16, 2018 04:34 PM
