After-Market stereo
Old Mar 14, 2019 | 04:02 PM
IfChris_ThenFit's Avatar
After-Market stereo
Hi all,
I am looking to install a Sony XAV-AX100 in my 2010 Fit so I can use Android Auto, and possibly a back up camera. I am gonna get the Metra adapter for double din. I wanted to know what the process of doing this looks like. Is it basically plug and play? Will I need to solder anything?
Thanks!
Old Mar 14, 2019 | 08:51 PM
mockginger's Avatar
If you have a black dash, I have the OEM Nav surround that you can have for free as long as you pay shipping. Everyone says the Metra doesn't match the dash finish so I went with OEM. I had the same head unit you're getting installed with this trim. No soldering required, just the regular wiring you would do for any head unit. I also have the wiring adapter for the head unit and steering wheel controls. If interested, pm me.
Old Mar 14, 2019 | 11:36 PM
Brooks_Church's Avatar
If he does not want the Nav trim, I do!
Old Mar 15, 2019 | 04:28 AM
mockginger's Avatar
I actually remembered I have the Metra kit also. Same price.
Old Mar 15, 2019 | 11:28 AM
Sadly I have a silver dash, and I feel that the black is too dark for my tastes. It is also gonna be a birthday gift technically and I dont wanna complicate it for the giver lol. I appreciate the offer though!
As far as the wiring adapter, what is that? and do I need to buy it separately?
Old Mar 15, 2019 | 11:35 AM
mockginger's Avatar
If you look up the head unit on Crutchfield and add to cart for your car year and model, it will show you the wiring harnesses you need to install it. You will have to buy both wiring harnesses and the dash kit all separately, but they typically give you a deal in your cart if you buy them all together.
Old Mar 16, 2019 | 10:37 AM
beardedGTI's Avatar
AX100 owner here. Parts you’ll need:
Notes:
  • no soldering required. You’ll want to use crimp connectors to tie the harness together. Just match color to color.
  • You’ll need 12v switched to power the antenna. Connect the blue cable coming out of the sony harness directly to the antenna adapter. Leave the blue cable coming out of the metra harness adapter unconnected. Despite what the metra package says, Honda does not have a 12v switched line coming out of the factory harness for the blue wire.
  • Tie the green parking brake cable to any ground.
  • Once you get everything installed, update your firmware on the head unit. Fairly simple procedure: https://www.sony.com/electronics/sup...loads/00015662
Old Mar 17, 2019 | 02:46 PM
Kazu's Avatar
I just recently did this install , wish I did a write up but I didn’t think people here needed it... it’s super easy. Don’t overthink it.
The hardest part was running the wire through that rubber hosing in the trunk door.
Pm me if you have any questions. I highly recommend Posi-twist connectors!
Old Mar 17, 2019 | 04:07 PM
Thanks everyone for the help! I will try to take pics and maybe make a thread of my process. Also installing a backup camera.
Chaney9516
Feb 13, 2018 04:08 PM
Snowman
Oct 15, 2014 01:08 PM
mebeingme
Aug 5, 2009 08:02 PM
CasopoliS
May 14, 2009 09:47 PM
varley_1031
Feb 18, 2008 10:51 AM
