2009 Honda Fit Sport slightly kicking and bucking
Old Mar 14, 2019 | 08:06 PM
mjf123's Avatar
My 2009 Honda Fit is slightly bucking and sputtering when accelerating AND also at stop. No codes. Background: Just had 2 tranny speed sensors replaced as that was original code that came up with bucking problem and flashing "D" gear light. Problem persisted so took to dealership. Installed OEM Honda specs oil filter installed, new fuel filter, fuel injection cleaned, did tranny flush and fill. Tune up at dealership last year with Honda OEM plugs). The dealership ran it for 30 miles hooked up to a computer diagnostics and everything checks out. No codes pop and still has light kicking spitting persists. Thoughts? Bad fuel pump...clogged fuel lines?
Old Mar 15, 2019 | 12:15 AM
Pyts's Avatar
So to clarify, no more light, right?
are your RPMs steady when accelerating, or to they move in an odd fashion? Somethin like that would indicate to me a fault with the throttle position sensor.
Now, if youd be so kind as to check/send images of all four of your spark plugs, that would say a whole lot. It'd rule out or verify any concerns with the fuel system/intake. I wouldn't be surprised to hear another loose spark plug story since its so damned common. I think instead of vins I'll just print out forum threads for honda, hah!
Sensors do fail, sometimes due to faulty manufacturing, but an HDS would pick up on something like that.
To test out your fuel pump is usually pretty easy. There's gonna be a little shrader valve somewhere in the line that'll let you spray the stuff everywhere. Plus! You can put your key in the ignition and turn it to on, where all the indicator lights turn on, and immediately listen for a wooshing sound that should last a bit over a second.
Old Mar 15, 2019 | 12:44 AM
Fiting's Avatar
Tough to know from the desk here in China.
Look for vacuum leaks with smoke test etc.
Dirty throttle body will prevent proper idle and drivability issues. Easy to clean (there is a special fluid for that and some instructions here regarding moly grease)
Clean your MAF also (use special fluid for that).
Check air filter is clean.
When is the last time you changed the battery? These tiny batteries don't have a lot of juice. Low power will cause some systems to become flakey, although other systems can run fine on low voltage. Get battery load tested at battery store or DIY load test.
Do a voltage drop test to make sure your main wiring at battery, alternator, to electronics, and all major grounds are good.
I have had bad throttle position sensor cause occasional engine racing/sputtering on a GM car. Very difficult to diagnose. Easy and cheap to replace. I don't know if that is a common Fit issue.
Old Mar 15, 2019 | 08:01 PM
fujisawa's Avatar
Plugs is the go to now looks like hehe.
Old Mar 20, 2019 | 12:36 PM
mjf123's Avatar
It was the tranny
Yup...so checked/repaired all the issues from people's responses. Very helpful so thank you all. It ended up being a bad transmission. Pile of metal in the fluid. Put in bottle of Lucas Transmission goop stuff for now. Ordered used tranny off Fit with only 47k miles. Will be installed by Tuesday by a shop. All in"?: $1300 parts labor/tax. The Fit shall live on!!
Old Mar 21, 2019 | 01:42 AM
Pyts's Avatar
Really sorry to hear that, and surprised too. thanks for letting us know.
Old Jun 1, 2024 | 01:19 PM
Pseast's Avatar
Is lucas transmission fix advised for Honda transmissions to keep the tranny going strong? I have gd and hear it may not be a good idea…
Old Jun 1, 2024 | 01:26 PM
mjf123's Avatar
Did not fix issue of blow tranny. Just kept it working for extra week while I set up repair. Which turned into a nightmare. The new transmission installed and never worked correctly. And then they installed 2nd incorrectly and it blew the ($2700) computer. 2 more tranmissions later did not not working right and new computer blew out again from bad install job. I traded car in for $1200 and got a 2018 Camry. 99k problem free miles so far.
Old Jun 2, 2024 | 09:52 PM
Pseast's Avatar
Ahhh…. Damn…
Liz10
Jan 13, 2020 05:25 AM
Akorenhere
Nov 14, 2019 01:12 AM
danielmorrison
Jan 31, 2019 12:55 PM
Santiad
Dec 9, 2011 11:30 PM
bleaubyou
Sep 11, 2009 12:31 AM
