Radio Keeps resetting!
Old Mar 18, 2019 | 01:14 PM
Lew's Avatar
Lew
So, I got a new battery and after 3 months my aftermarket Alpine radio has started resetting itself after what seems every other stop/start. This was happening just before I got the new battery. Crutchfield says that the radio will do that if it is not receiving enough power. I used an aftermarket harness to plug into dash so no wires direct to battery. Thanks for any help anyone can offer! 2009 Fit Sport Auto
Old Mar 18, 2019 | 05:20 PM
GolNat's Avatar
Pull the radio out and check for any loose wiring.
Old Mar 18, 2019 | 08:28 PM
Action Jackson's Avatar
Must be some issue with the yellow constant on power.
Old Mar 19, 2019 | 10:23 AM
Lew's Avatar
Lew
Put a multimeter on battery while started. 13.5 at idle, 13.6 at 2500rpm, watched it drop from 12.5-12.1 in 3 minutes after shut off. Drops to 9.9 when key turned to start. Maybe alternator?
Old Mar 19, 2019 | 01:15 PM
GolNat's Avatar
Did you pull the radio out?
Start with the simple stuff first. If the radio is the only thing acting funny then it is probably the radio or radio connection.
Old Apr 30, 2019 | 06:14 PM
Lew's Avatar
Lew
Not the Radio
Switched with an Alpine that is a couple gens old. It didn’t reset for the 3 weeks I had it in. Put newer one back in and it started to do the resetting thing again. Bought a “working” radio of the same model and it does the same thing. Yellow memory wire hooked directly up to battery. Alpine says stereo needs at least 11 volts or it resets. Could the car start drawing the battery down past 11V AND reset radio? This is weird.
Old May 1, 2019 | 01:50 PM
steve37's Avatar
I don't know the answer to the resets. It sounds like a bad connection somewhere.
I do know that I don't like my Alpine CDE-175BT at all. I've had it a year and I wish I had never picked that receiver.
Years ago, Alpine was always quality...not anymore..imo.
Old May 4, 2019 | 08:46 PM
ChuckDustin's Avatar
Clean your battery terminals, connectors, and ensure that they are seated and making contact 360 degrees around.
Thats where I'd start.
Old May 4, 2019 | 08:47 PM
If still no luck I'd whip out the multimeter and start testing some connections. Got2b power related
2007Fit5AT
Feb 23, 2015 06:03 PM
SilverEX15
Aug 28, 2014 04:15 PM
vickenp
Oct 20, 2011 04:23 PM
kentris
Aug 14, 2006 12:48 AM
Jon Waisnor
May 4, 2005 11:16 AM
