Remove Spark Plugs Before Adjusting Valves?
Old Mar 23, 2019 | 02:14 PM
Mister Coffee's Avatar
I must be getting old. I cannot remember. But it seems to me that I used to remove the spark plugs before adjusting the valves in order to release the compression in the cylinders (so that the crank would turn by hand).
What do you guys do?
Thanks.
Old Mar 23, 2019 | 03:57 PM
USDM's Avatar
Old Mar 24, 2019 | 10:46 AM
hotkey's Avatar
I also removed plugs before valve clearance adjustment way back when. Made it easy to press on the fan belt w/ one hand while the other hand was on a fan blade to rotate the crankshaft. Since you needed to check the plug gaps or replace them anyway ..... it just made sense.
Old Mar 24, 2019 | 11:11 AM
Duly noted, gentlemen. Thank you.
g fit
Nov 5, 2015 11:31 AM
wackyflik
Oct 4, 2014 09:11 AM
hogwylde
Aug 14, 2011 07:35 PM
kylerwho
Feb 8, 2009 07:23 PM
bryan720
Feb 17, 2007 08:06 PM
