Fog light
Old Mar 27, 2019 | 10:01 PM
xLilFantasyx's Avatar
Fog light
I have a 2018 honda Fit sport and was wondering how do you replace the fog lights. How to remove to get to the bulb?
Old Mar 28, 2019 | 10:14 AM
Dphollings's Avatar
Exclamation
You're going to have to get behind the bumper cover to access the bulb. You may be able to undo some paneling underneath and reach inside without removing the bumper cover. I was able to replace the foggies on my '05 civic si by undoing fasteners on the underside of my front end and reaching my arm all the way inside. The correct way to do it is remove the bumper cover, unplug the bulbs, and remove the bulb from the fog light housing assembly. Also make sure you try unplugging and re-plugging the bulb to see if it was a bad connection before replacing the bulb and wasting money. Use dielectric grease on the bulb connection to prevent corrosion. Also DO NOT touch the glass area of the bulb or get any grease or oil on it. If you do you must clean it off before providing power to the bulb. The bulb gets very hot, if there is oil or residue on the bulb then that area of the glass will dissipate heat differently and lead to the bulb possibly cracking.
Old Mar 28, 2019 | 10:46 AM
hobbes87's Avatar
You have to turn the wheel completely one way, take the inner wheel liner off, or remove enough screws so that you can pry it out of the way to stick your arm in there.
Old Mar 29, 2019 | 08:34 AM
2Rismo2's Avatar
There is a screw holding a little trapdoor that gives you access to the fog lights so you can replace the bulb. Might be easier to have it lifted up a bit. I usually drive over the transition to my garage and that's enough clearance.
Old Nov 9, 2023 | 07:34 PM
Cbritt04's Avatar
I Also have a 2018 Honda fit sport, and the extra trim + spoiler makes it difficult to access the fog lights, tomorrow i am going take a closer look
Sujeto
Oct 20, 2016 05:52 PM
ImJoeShmoe
Jan 19, 2016 04:53 AM
Ron's Auto Care
Jun 24, 2012 05:21 PM
sav_fitatsos
May 2, 2011 06:40 PM
AnlDyxp_GD3
Apr 28, 2010 12:10 PM
