Awd swap
Old Jun 1, 2019 | 06:55 PM
Bend's Avatar
Awd swap
Hello i have a 2004 honda jazz uk my dad gave me his mk1 crv with a b20 and im going to swap the crv engine and drive train into the jazz will be modifying the driveshafts and propshaft to fit was wondering is the front hub flange as its splined would fit the rear hub is it the same depth were the bearing is pressed onto and if its the same diameter or would i have to get a wheel bearing made up cheers ben
Old Jun 1, 2019 | 07:35 PM
fujisawa's Avatar
Where is the prop shaft going to go?
Old Jun 3, 2019 | 04:06 AM
Bend's Avatar
I going to cut and box a trans tunnel if the 1 thats there isn't deep enough to run the prop pretty easy as the jap models they had a awd model just using the measurements from that
K24jzz
Jul 3, 2018 04:05 PM
jackanyon
Nov 29, 2017 06:39 AM
giliav
Jun 17, 2016 01:30 AM
crisscross
Nov 20, 2010 08:48 PM
willem
Jan 31, 2007 01:26 AM
