Cabin air filter
Old Jun 27, 2019 | 09:53 AM
pablolo's Avatar
Cabin air filter
Hi everyone. I own a 2013 Honda Fit Base. I wanted to know where I could purchase an inexpensive cabin air filter? Thank you
Old Jun 27, 2019 | 10:08 AM
Fiting's Avatar
Buy a high quality cabin air filter. There is much more material on it so it lasts much longer so is not much more expensive in the long run.
A clogged cabin air filter can cause the fan motor to heat up and kill the resistor pack (and maybe the motor also). Those are rather expensive parts and the Fit has a history of blowing them.
So with some cars, a cheap cabin air filter is fine but those are false economies with the Fit.
Old Jun 27, 2019 | 11:27 AM
2012FitFan's Avatar
I use this one. I change it once a year. Filter looks great every time I remove it, with typical debris and no clogs.
https://www.amazon.com/ECOGARD-XC36080-Premium-Filter-Insight/dp/B00I8IU150/ https://www.amazon.com/ECOGARD-XC36080-Premium-Filter-Insight/dp/B00I8IU150/
Old Jun 27, 2019 | 12:03 PM
pablolo's Avatar
Cabin filter
Thanks for the recommendation for Amazon cabin filter.I watched a YouTube video and it took the man about 25 seconds to remove and replace the cabin air filter
Old Jun 27, 2019 | 12:47 PM
2012FitFan's Avatar
Yes. It’s very easy to swap out.
Old Jun 27, 2019 | 01:15 PM
silverrose12's Avatar
that ecoguard is not bad at all. pretty decently priced. i was looking at K & N cabin filters, but they cost upwards of $45... i dunno what they put it in their filters..
Old Jun 27, 2019 | 04:54 PM
spike55_bmw's Avatar
I think I need some 'area denial' spikes on my cabin air filters to keep the mice off of them.
Old Jun 27, 2019 | 05:27 PM
o.O how does that happen?
Old Jul 12, 2019 | 02:02 PM
Fit2Bsquare$'s Avatar
That's wild! A rodent problem in a Fit.
Old Jul 12, 2019 | 04:13 PM
fitchet's Avatar
I think I agree with the philosophy of not going too cheap on the Cabin Air Filter.
And the way I look at it, if you buy one yourself...online or at a auto parts store, even if you pay a little more, for a higher quality filter, and you install it yourself (easy), it's going to be a whole lot cheaper than a dealership doing it.
So I would look to buy a better quality filter, then just replace it yourself. It's not going to cost you too much. It's filtering the air you breath in the cabin. I think it's worth it.
Old Jul 12, 2019 | 04:36 PM
evilchargerfan's Avatar
I own both a K&N re usable / washable cabin air filter, and also a ECOGARD XC36080
Every 12k I wash the k&N, and while its out drying I use the ecogard one as a one day stand in
The K&N was not cheap, but so far, I've already gotten 3 life cycles out of it, and once I wash/re use it a 4th time, it will pay for itself. by the time I hit 120k, thats 10 uses out of this thing .... and imo makes it worth every penny.
Old Jul 12, 2019 | 04:56 PM
OH its washable? hmm interesting ...i might actually try getting K&N next time
Old Jul 13, 2019 | 06:50 PM
Frenzal's Avatar
I also have the K&N cabin filter (as well as the K&N air filter). So far so good! (4th wash)
Old Jul 14, 2019 | 08:31 AM
fitchet's Avatar
I say just buy a NEW filter.- New is new.
I don't personally believe the concept that something that is being washed, the rewashed, washed again...doesn't deteriorate.
If it takes 4 cycles or more just to recover the cost of initial investment? That ain't worth it to me.
I feel better just treating the cabin air filter as a non-permanent, replaceable part. Feel better just installing a brand new, clean, NEVER washed and reused filter.
But to each their own.
Old Jul 14, 2019 | 01:06 PM
Washable filter seems like a good plan.
Good way to reduce waste in a world in which people think throwing everything away is totally okay...maybe if you're old & don't care for your grandkids.
Old Jul 14, 2019 | 03:51 PM
USDM's Avatar
How many cycles would you consider fair to recover the cost of initial investment? It's kind of nice knowing your filter is good for pretty much the lifetime of the car. I run a K&N drop-in air filter in my car and have zero issues.; just remove it every 10,000 miles and give it a clean and we're good to go again. I'd be willing to bet you wouldn't be able to discern a difference between a reused filter and a new one.
Old Jul 14, 2019 | 10:25 PM
Brain Champagne's Avatar
Does this washable air filter have to get cleaned and re-oiled? Not sure if that's better for the environment than throwing a replaceable one out and using a new one.
FYI even the replaceable ones can be taken out, banged a bit to dump dust off them, then replaced, until they fully need replacing.
Old Jul 15, 2019 | 07:42 AM
I bang mine out to clean until there's too much rat piss on them. Gross Then I'll change it out for another replaceable. BTW, I had a 'trap line' set up, plus electronic mouse repellent devices plugged into all four corners of the garage, so not 'wishing' the problem would go away, but it's on-going. I should make gloves out of each year's trappings
Old Jul 15, 2019 | 08:35 AM
punx45's Avatar
you're not sure if rinsing it with a little water, (maybe some soap?) and a light coat of oil is better for then environment than whatever results from the manufacturing plant, shipping, packaging, retail store, driving to and from the store to buy it, and then throwing the old one (and the packaging from the new one) into a landfill, or incinerator?
Old Jul 15, 2019 | 09:15 AM
Yeah, exactly. Especially if you also have a K&N drop-in engine filter and can wash that as well. Those kits last a LONG time.
