Sponsored by:
Sponsored by: CARiD
Always on (constant) fuse?
Old Sep 11, 2019 | 03:19 PM
seditious3's Avatar
I've seen this question, but no definitive answer. I have a dash cam that needs both switched and constant power. The switched is easy. Is there an always-on fuse in the footwell fuse box. Is there a wire I can tap into without running a wire from the battery? I'm open to suggestions.
Thanks!
Old Sep 11, 2019 | 04:02 PM
GolNat's Avatar
Grab a volt meter/test light and start poking around. THe ignition switch and radio will have an always hot wire.
Old Jun 7, 2021 | 03:30 AM
Moksaphoto's Avatar
Lightbulb Constant power in the fuse box of a 2006 Honda Jazz, Fit for dashcam or anything else
I am not a car mechanic but just hate to sit and wait for someone else to help me out, so I do my own experiment with things... therefore use my advice on your own responsibility.
I have a 2006 Honda Jazz and I found that fuse number 20 has constant power regardless of the state of the engine.
I wanted to install a dashcam into my car so it does not take my cigarette lighter socket plus it can record everything even when I am in the parking lot. Since apparently No# 20 is not used for anything anyways, it will not interfere with other important electronic parts if I play with it, and it is safe to use. I plugged an "add a circuit fuse tap" adapter into the fuse slot and a switch that I can turn the power of the camera on and off whenever I want to.
So far so good, everything works perfectly fine. I was running my Vantrue Pro 2 with the screen on the entire night and morning and the battery did not even feel anything. I am not sure if the circuit that came with the camera has safety turn off protection in case of low voltage but if it can be on for a whole day without any problems, I am not worried.
FTBT
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
Aug 1, 2019 03:54 PM
Dedroberts
Jul 22, 2018 12:52 AM
SilverEX15
Aug 30, 2014 09:54 PM
stock0891
Feb 20, 2010 04:06 AM
TWGE08
Jun 10, 2009 07:54 PM
