P0700 & P1705 after instrument cluster change
Old Oct 9, 2019 | 09:06 AM
Iftimie Cristi's Avatar
I had to replace my old instrument cluster because I shorted some pins of the brightness adjuster and the speedo, mileage recorder and the small display for the 7 speed mode were not working anymore.
The problem is that when I connect the new cluster there 2 codes showing: P0700 & P1705 and S light is on with D flashing.
Is this just a matter of recoding the new cluster? When I put the old one all this codes go away
Old Oct 13, 2019 | 09:26 AM
elkaku's Avatar
It looks like it is a problem with the transmission.... check this out...
p0175 code checkup
Old Feb 8, 2023 | 09:14 PM
Saji's Avatar
Hi mate, did you manage to fix this issue? The same thing happened to me when changing the cluster and the same DTC turned up..
tyler968
Jul 11, 2019 05:02 AM
randomracer
Jun 11, 2014 10:05 AM
gkitf16
May 8, 2014 10:11 PM
gkitf16
May 7, 2014 07:03 PM
.eL
Apr 8, 2010 07:16 PM
