Swapping 2013 Fit Battery
Old Nov 11, 2019 | 03:22 PM
autumnalpoisons's Avatar
So this is my first honda (used to Dodges). I was suprised by this fuse box on top the terminal. It has 3 bolts on the box itself and a larger maybe 12mm? 13mm bolt next to the post. What do I need to remove to swap the battery? I don't want to disassemble the fuse box if I don't need to. I've already taken off the battery terminal bolts.
Old Dec 18, 2019 | 03:52 PM
KoalaMTL's Avatar
You don't disassemble anything in the fuse assembly you're mentioning. That whole fuse assembly is connected to the terminal bolt
So - you just undo the terminal bolt and lift the whole assembly off as one unit. See picture.
Old Dec 23, 2019 | 04:23 AM
fitturismo's Avatar
My 2012 had a bar clamp on top of it but it was just two nuts on a post screw
Old Dec 23, 2019 | 03:54 PM
KoalaMTL's Avatar
From what I've seen, it seems like only the 2013s are blessed with this weird battery fuse assembly on the positive terminal bolt
Old Dec 23, 2019 | 07:12 PM
GeneralLee86's Avatar
Yeah my 2013 has it too but after a 1 yrs with stock battery I switched the D51R Yellow top Optima battery and haven't regretted it since, I also use my Optima Digital 1200 charger for Maintaining it when not driving so I haven't had problem with it so far.
Old Dec 31, 2019 | 05:47 PM
R290's Avatar
Cool
I did the battery upgrade to a larger battery 51R, replacing the riding lawn mower sized Fit battery. It was like 2 years ago on the 2012 fit.
I do remember getting the angle grinder with a cutoff wheel out to make some change. I figure the car works for be, not the other way around.
Much easier to find a 51R battery when in need next time.
Craig Cole
May 23, 2025 10:55 PM
douglasd5
May 23, 2025 10:49 PM
HackerExecute
Oct 5, 2020 12:37 PM
Arty163
Dec 24, 2018 05:08 AM
phoenity
Nov 12, 2012 03:07 PM
