Front strut "clunk" and play issue
Old Dec 25, 2019 | 08:25 AM
ChrisA70's Avatar
My 2016 is getting a lovely "clunk" over bumps on both sides. I am taking it in to the dealer 12/27 AGAIN. I bought it from them on 11/11/19 and for the second time to have them find out why there is so much play in the strut mounts. I took it to their sister dealership, and they said they couldn't hear anything and the service manager basically called the Fit an inferior product, and a cheap car, so I have to deal. So I got pissed and got ahold of the main dealer I bought it from an hour away, and they are taking it in to make sure it gets fixed.
If you lift the front end a few inches off the floor, and pry up and down on the tire, you can hear the obvious clunk, and feel the clunking/movement on the upper strut mount. I think the strut bearings are shot, and or the rubber strut mount. All I know is I didn't pay $14k for a clunky front end. I drive my CRV so I don't get irritated by the noise. I like my Fit, but they need to fix it right.
Anyone else get this with theirs?
Old Dec 26, 2019 | 09:56 AM
silverrose12's Avatar
i am going over similar issue.
my front driver side wheel is making noise when i go over bumps.
its not a grinding noise, nor metallic noise.... kinda like loose plastic noise? not sure how to describe it.
hope you get your fixed =S
Old Dec 26, 2019 | 10:56 AM
ChrisA70's Avatar
Same, no grinding noises, nothing else like that, but when I am between 5mph and about 30, any small bumps, ruts, etc. sound like I am driving over a small curb!! Definitely a clunk from bad strut bearings or a worn strut mount. When I lift the car about 3" off the ground and quickly pry up and down I can hear the clunking, and feel it when my hand is on the strut mount up top, and feel it move up and down 1/8-1/4". NOT normal. Because my CRV has 0 play and it's a 2008 with 150k on all original struts.
Old Dec 26, 2019 | 06:07 PM
bill bosco's Avatar
the service manager actually told you it was an inferior product so deal with it ? i would write to honda , with a copy of the bill and the service manager's name .my '90 civic was under $7k , had no clunks in the front end or anywhere else .
Old Dec 27, 2019 | 06:02 PM
ChrisA70's Avatar
Yep, he basically said the Fit is a cheap car, and that's the way they are. ALSO the parent dealership today said basically the same thing. I was told to drive a 2017 and it was basically the same. So in a couple months I am replacing the front struts with KYB, new bearings, and strut mounts. The dealer can kiss my ass. I'll fix it myself....
Old Dec 27, 2019 | 07:31 PM
Hootie's Avatar
Welp, I'll just say that is unprofessional and a load of BS from the managers in regards to the build quality.
How many miles are on your 2016?
Did the tech(s) leave a detail story of their diag in regards to trying to source the noise?
Did you and/or the tech check for any abnormal gaps between the upper strut damper and were it contacts the body of the vehicle?
Did you and/or the tech test drive the car with the front anti-roll bar end links disconnected to confirm/deny it as the source of the noise?
Old Dec 27, 2019 | 07:50 PM
ChrisA70's Avatar
37142 miles on it. I replaced the links myself after I bought it, since 9 out of 10 times the end links are where most front end noises come from. No change afterwards. Except the links I put on were twice as thick as the OEM ones so it felt tighter in turns.
They said it's the design of the car itself. It has that small play to allow the tilt when turning the wheel. I said well that sucks, because it's pretty annoying. I told the kid if I put my own parts in, and it stops, I will send them the bill LOL... He just looked at me. I still think it's the lower damper and bearings but whatever.
I will add pics of the upper damper, it looks pretty normal, no crazy gap.
Old Dec 28, 2019 | 06:49 AM
bill bosco's Avatar
strange , to my knowledge , that's not an issue that's been reported on the fit in consumers
Old Dec 29, 2019 | 08:21 AM
ChrisA70's Avatar
I know, I researched the hell out of this clunky sound. I did find a few complaints on noisy front ends on the 2015-2018. These guys are writing it off, so I am just going to replace what I feel is the issue. And after I do, if it stops the noise I will be damn sure to run the dealer through the mud.
Old Dec 29, 2019 | 12:14 PM
Fuelish's Avatar
Yeah, but....doesn't mean it can't be an issue on OPs car, right?
Old Dec 30, 2019 | 03:23 PM
wasserball's Avatar
Agreed. I have '17 LX with 50K mostly freeway miles. No issue with front end clunk or steering play.
Old Dec 30, 2019 | 03:24 PM
wasserball's Avatar
Well, you never know what the original owner did to the car. OP bought it used I believe. A carfax report may be able to trace the issue. That would not resolve the problem, but at least it would rule out that the Fit, which is a "cheap" car, but not in a functional way.
Old Dec 30, 2019 | 04:38 PM
Fuelish's Avatar
True, no argument....our '15 has 61,000+ on it, bought used CPO in '16, never had a problem other than a couple of small fingertip sized blotches in the factory paint that looks like they painted over bird poop or something, and the typical "cold start grind," which occurs rarely here in east TN as winters are pretty mild in the scheme of things. I lucked out, but, yeah, if bought used, all bets are off
Old Dec 30, 2019 | 07:30 PM
bill bosco's Avatar
possibly the nuts on top of the struts were not torqued properly and the extra play over time wasted the bearings and or the bushings on top of the struts
Old Jan 29, 2020 | 07:44 AM
ChrisA70's Avatar
So this morning I ordered a set of new KYB struts for the front, OEM Honda front strut mount, new strut bearings(and nut), plus 2 new upper strut dampers. So in the next couple weekends I will be replacing ALL of the above. THEN..... If this car is more quiet, and the knocking goes away I will be letting Lundgren Honda of Auburn how much they SUCK, or don't. Will keep you posted.
Old Jan 29, 2020 | 08:56 AM
Jazu's Avatar
Stealers....can't live with them - can't ______ them. I paid for a tire rotation that didn't occur just recentl. I marked the tires with a red clay pen ahead of time and had the show the Manager in front of all her service techs at Prime Honda (Boston). Now tire rotation is done at home.
Old Jan 29, 2020 | 11:05 AM
ChrisA70's Avatar
I do everything myself and less it’s something I absolutely can’t do. If that’s the case I take my car to the dealership my brother is the service manager off and he make sure sh** is done. I don’t trust any other dealerships and I will never go back to Lundgren Honda again for any reason they can kiss my right cheek.
Old Jan 29, 2020 | 11:29 AM
bargainguy's Avatar
I've found my state's Consumer Protection dept. a valuable resource as far as dealer rip-offs. Registering a complaint - something most people won't go through the trouble of doing - is how I get started.
In my state, once you initiate a complaint against a business, that business is mandated by the state to respond. If it's a national company, the complaint will find its way to the corporate office, not the local one, for the official answers.
That gets the attention of the manufacturer in a hurry. They know they can't bamboozle state officials the same way as they could one person.
Old Feb 1, 2020 | 08:42 PM
ChrisA70's Avatar
Box of genuine Honda replacement parts came in today, struts Monday, and new End links this week too. Can't wait to replace this stuff, hopefully to throw it in the dealers face.
Old Feb 3, 2020 | 01:38 PM
evilchargerfan's Avatar
will you be replacing that super soft nut on top?
