revist Fit on nitrous... video with sound
Old Dec 5, 2006 | 08:01 PM
805FitSport's Avatar
Thumbs up revist Fit on nitrous... video with sound
so finally i got a vid for you guys with some sound after all this time, this time its from a 2nd gear roll, 30-105 MPH 50 shot of nitrous, with fujita CAI, T1R test pipe, FULL INTERIOR.
http://www.youtube.com/watch?v=T8HlQX0oL24
enjoy!
Old Dec 5, 2006 | 09:09 PM
gettinafit's Avatar
SOunds nice and looks fast!
Old Dec 5, 2006 | 09:25 PM
firstshadow's Avatar
Senior Member
dam thats hauling a$$ lol
Old Dec 6, 2006 | 12:01 AM
JERKsFIT's Avatar
nice video
Old Dec 6, 2006 | 01:04 PM
i was thinking id might up the shot, ive been on this shot for over 4 months now, changed plugs once, and added the T1R test pipe which made a big difference when spraying. ive been wanting to add a bottle warmer because its getting really cold out here and my bottle pressure is always below 900 psi, that said the car is running pretty rich.
Old Dec 6, 2006 | 04:06 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Nice little vid. Looks quick!
How did the plugs look when you pulled them? The clutch is holding well? Im interested to know if the clutch will hold a 75shot.
RUN THE CAR!!!!
Old Dec 6, 2006 | 04:34 PM
RUN THE CAR!!!!
when i pulled the stock plugs at around 8500 miles they still looked good, i got another pair of stock iridiums from honda and gave them a closer gap. i will get step colder plugs before i up the shot, i think my fuel silenoid is going bad though. so i will buy another one of those as well.... as far as the stock clutch goes, ive been spraying with this car from 5000 miles and up, i have 13K now, and it spins the tires hard going into 2nd gear,i really need a cat back though. the stock exhaust is holding the car back for sure, not the mention the restrictive exhaust manifold. so yea the stock clutch is perfect!
Old Dec 7, 2006 | 09:36 PM
kz098123's Avatar
How long does a full bottle last for for you? And how much to refill them? I've never priced out n2o before.
Old Dec 8, 2006 | 07:42 AM
smeister's Avatar
That 50 shot sure makes a big difference. So how are you getting the car to run rich?
Old Dec 8, 2006 | 05:34 PM
it will cost about 40 dollars to fill a 10 lb bottle around were i live, and it last a long time because the shot is so low...
Old Dec 8, 2006 | 05:36 PM
the car is running rich because of the low bottle pressure, with a bottle warmer i should be able to get it up to around 1100 psi which will make a world of difference then it being at 900 psi
Old Dec 8, 2006 | 05:46 PM
ive been really busy building my STi but i will be getting the T1R pulley on the car as soon as i have more time, hopefully ill see some gains, and i will also be getting a header (waiting on AJR for its release)..... the car will still be bottle knecked at the muffler and mid pipe section till i get some more money.
Old Dec 8, 2006 | 05:49 PM
kimo's Avatar
Have you made any mods in the fuel line to install the NOS.
Old Dec 8, 2006 | 05:54 PM
as i explained in the other tread, you will need to replace the fuel line because its plastic sleeved with rubber hose, you will need to tee off from there to get your fuel for the wet system.
Old Dec 8, 2006 | 05:57 PM
kimo's Avatar
I am buying my kit from http://www.racetested.com/ but I will use at first 25 shots and go up, as my car is 1.3L.
Old Dec 8, 2006 | 06:04 PM
looks pretty cool, alot of features, plus i like the life time warranty on the silenoids, my kit was on my honda pilot that was all peiced together from alot of used parts, so ive had to buy more and more parts over time to keep working. all i have is an armng switch, and a push button.
Old Dec 8, 2006 | 06:11 PM
kimo's Avatar
Ya they are nice but $$$ compare to others.
Emirii
Aug 17, 2014 11:43 AM
Cipher
Mar 30, 2012 02:30 PM
ImSorryWhat
Feb 4, 2012 01:18 AM
GUESTO
Jul 5, 2011 01:28 PM
vafitfreak
Dec 7, 2006 02:11 PM
