AC problems
Old May 9, 2020 | 01:35 PM
Grant Wertheim's Avatar
AC problems
Okay so I havent found anything about this yet; hoping someone knows whats up. AC blows hot air ; doesn't need refrigerant though (added some and nothing worked) ac blows hot air. Whats the problem? I can fix it myself I just wanna know whats wrong without having someone charge me 100$ just to look at it.
Old May 9, 2020 | 09:42 PM
Red 05's Avatar
What generation Fit? If second gen look into replacing AC compressor relay behind driver headlight. That was what broken on mine last year
Old May 11, 2020 | 01:34 PM
Reply;
Generation? Im not sure how do I figure that out? But ill look into checking the AC compressor relay. Thanks for the help!
Old Jun 17, 2020 | 03:50 PM
Pablo_Sevilla's Avatar
Grant, what year is your car? Do you see the AC compressor clutch engaging when you turn on the AC?
If the AC works but you still get hot air, it could be that there is something wrong with the cold/hot air mixing inside the dashboard HVAC unit
BigSpark
May 7, 2021 03:42 PM
Fitforthefirsttime
Aug 26, 2019 08:35 AM
psamtik
Jun 26, 2018 11:39 AM
phybere
May 29, 2018 11:46 PM
lasvegas
Apr 13, 2012 08:18 PM
