AC Blows Ambient Temp - No Clear Solution
Old May 15, 2020 | 04:40 PM
craz's Avatar
Hey guys, I've been troubleshooting my 2012 Fit Sport's AC for a few days now. Blows ambient temp, no cooling happening at all. When it "worked" it did the typical blow kind of cold for a while, but blow warm after an hour or so. Turning the AC button off then on for a few minutes helped. Then over the course of maybe a couple of months, the system degraded to no cooling whatsoever. I've done troubleshooting, but I can't seem to pinpoint a cause.
Manifold gauge readings (about 70 deg F ambient):
Compressor/Engine off: 100 Low, 100 High.
Compressor On: Low cycles between 15-30, High is consistent at about 165
Things I've Checked:
Compressor: clutch engages (short cycles at idle)
AC Button: Compressor turns on when the button is pressed and light is illuminated
Blend Door: I can hear a change in the air flow when I actuate the hot/cold knob in the cab, and flow velocity is perfectly fine
Fans: The fans come on. Regardless, there's no cold air while driving either.
Other Observations:
There has always been a hissing sound coming from the vents when the compressor was on. This still happens. Right before the AC went out for good, the hissing sound intensified.
Both Low and High lines are warm to the touch along their entire visible length
I'm thinking of playing it safe and replacing the Expansion Valve, Evaporator, Condenser, and Drier, but if its something easier then that would be great.
I know this was a lot to read, hopefully someone can help me piece this together. Thank you!
Old May 30, 2020 | 12:09 PM
mrbawkbegawks's Avatar
do you have a grill on your car? ac condenser is infront of radiator... so if you ever drive on gravel or the highway things are going through this ($300)and not the radiator($50)
Old Jul 11, 2022 | 02:57 PM
The Kev Master's Avatar
I was in your boat. Fill the thing up some with nitrogen or R134a, and look under the car. I happened to see the R134 coming out the condensation pipe. The evaporator coil was damaged.
I got around to fixing it after 8 years as I have another to drive but 3.5 V6 ain't cutting it with gas prices where they are at
Fitforthefirsttime
Aug 26, 2019 08:35 AM
phybere
May 29, 2018 11:46 PM
taxonomy
Jun 17, 2017 10:08 PM
Austinite
Jul 4, 2015 01:42 PM
asiab3
Jul 22, 2014 07:34 PM
