Fit 06 GD3 with Work CR Kai wheels measuring 17x7+47 problem
Old Jul 26, 2020 | 11:48 PM
Tanagorn Lorsubkong's Avatar
Hi All,
Been reading/researching to search used after market my fit 2006 VTI-s (from Melbourne).
Untill I found Work CR Kai wheels measuring 17x7+47.
My Stock wheel is 15x6 +53 (195/55 R15).
After doing all numbers in willtheyfit.com, pretty confident that it will fit ok. However I went there and asked the owner to try them on.
The wheel is rub with the break. Please the pictures that i attached.
Would like to hear opinion and suggestion option I have if wanna make this wheel work or should not buy these wheels
Thanks in advance. So Appreciated everything I read and learn from FitFreak
Stay safe &
Old Jul 26, 2020 | 11:55 PM
Old Jul 26, 2020 | 11:56 PM
Old Jul 27, 2020 | 12:11 AM
GolNat's Avatar
I don't see a picture.
If it is hitting the brake caliper then you will need wheel spacers to move the wheel away from the hub some.
Old Jul 27, 2020 | 12:15 AM
Old Jul 27, 2020 | 12:16 AM
I think the pictures I post will not be visible until a moderator has approved it for posting
Old Jul 27, 2020 | 12:29 AM
Hi GOINat,
Thanks for reply.
I got a clearance number to ask too
-Refering to willtheyfit.com calculation, the work CR Kai 17x7 +47 will stick out from where my stock wheel about 18.7mm
-from thread research,usual people can put hub centric space up to 25-30mm to stock height and stock wheel
-Is that me max spacer thickness that I can put will be vary from 6.3mm (6mm )to 11.3mm(11mm)
-If spacer thickness is greater than 6-11mm, Is that mean I have to do working/ rolling fender?
Did I understand numbers correctly or any suggestion is greatly appreciated
Love you all
Old Jul 27, 2020 | 01:17 PM
GAFIT's Avatar
The stock wheel is an inch narrower which throws off the numbers for offset.
In this case, the fitment issue is the wheel spokes making contact with the caliper. You just need enough spacer to clear the caliper. As little as 2mm may be enough. If possible, I'd buy a 4 pack of 2mm thick spacers and then see if 1, or 2, or 3 are needed. Then you'll know.
Old Jul 27, 2020 | 01:40 PM
Old Jul 27, 2020 | 05:09 PM
GolNat's Avatar
Fenders will only need to be rolled if the tires are hitting them.
You can run whatever size spacer you want technically but I wouldn't run past 25-30mm if I could help it. **Also remember you will need longer wheel studs with spacers so longer ones need to be pressed in. Don'f forget to match the lug nut seat style also**
If the wheel sticks out too far the car will look silly IMO. Some people like that look it's up to you.
Like GAFIT said you just need enough to clear the caliper. That could be 2mm to 30mm depending on the barrel and spoke design of the wheel.
I'd personally get different wheels if they are going to stick out too far.
This looks silly to me but some folks like it.
Old Aug 2, 2020 | 09:25 AM
Hi All
just missed out on these wheels as someone bought it before me. Thanks
Oblio
May 13, 2019 09:43 AM
plee82
Dec 8, 2015 09:14 PM
annunC8
Oct 14, 2010 11:46 AM
Solscud007
May 26, 2009 12:29 AM
goosala
Apr 24, 2006 11:22 PM
