Creaking from front-left wheel - 2009 Fit Sport
Old Sep 18, 2020 | 05:23 PM
MJetz's Avatar
My 2009 sport (104k miles) has recently started making a sharp creaking noise (I would describe it as similar to the sound of an old creaky door, but faster), coming from the driver-front wheel area. I've found similar complaints on this forum but those were specific to cold temperatures. My issue doesn't seem to be temperature-sensitive.
I've had it happen in 3 ways:
  • When turning hard to either side while reversing, say when reversing from a parking spot
  • If I'm driving slow, say around 15mph, and then brake firmly. It then often also creaks when I set off again. But if I braked gently, it doesn't do it.
  • When going over a speed bump, but it's only happened this way once or twice.
I brought it in to my local garage twice and the issue still persists. First they found that the driver-front wheel was a little bent, so they moved it to the rear but it didn't help Then they replaced the control arm, but the noise persists.
Any ideas?
Old Sep 27, 2020 | 12:24 PM
Red 05's Avatar
The rubber perch that the strut mounts to the top of the shock tower with can perish and become brittle. I get a little squeak when it's cold going over speed bumps from mine
pushpop
Aug 22, 2015 03:21 PM
Baldwin8814
Aug 19, 2015 09:24 AM
Lobo1101
Jun 3, 2014 06:02 PM
swell6
Jan 14, 2014 06:00 PM
vwli
May 25, 2010 01:59 AM
