My 1st 2009 Fit M/T Sport Problem
This morning when I started driving the Fit, there was a high pitch metal grinding noise at the rear wheels. Pull and release hand brake a few times make sure it is not on, same noise. Ended up getting a ride from my wife to work. Make an appointment on Thursday at the dealer to have it check out. Currently at 28,000 miles. Have me second guessing reliability of the Fit. Will keep you guys updated what's wrong.
Sounds like the handbrake is stuck. It might be as simple of a fix as applying some grease to the cable. Sorry to hear you've been inconvenienced though - that's the same whether the problem with the car is big or small.
I wouldn't write off Honda because of it though. Surely the "vw" in your name doesn't stand for volkswagen or you would be praising 28k with no problems!
Noise Gone
I re-activated insurance on my other car so I can get to work tomorrow. I started the Fit and moved it out of the way so I can back the other car from the garage. It squealed for a while and all of a sudden the noise went away. May be it was some debris got stuck and fell off.
The weather is nice anyway. I might as well start driving my G20 again. Sharing duty with the Fit.
K_C_
Dan
I had this over the winter and it was debris that just worked itself out very quickly. Freaked me out though. It's been fine ever since. The rims on these cars are pretty open to such things, it seems to me. If it's fine now, I would consider it was a little pebble or something that worked itself out. Good luck.
Dan
Dan
Come to think of it, another storm is when I got the debris in the wheel. Probably salt. But that screech threw me for a loop! Just a quick drive forward for about 100' and it worked itself out. Phew again!
Dan
Btw, I've also encountered that 'flash rust', but on the front brakes. It's clearly visable yellow. It happend over a three day rest- pretty freakin quick. Backing out, it didn't screech but it was a noisy rub, that's for sure. That quickly wore off after a couple of breaks during normal driving.
an
an
.eL
Jun 25, 2010 01:41 PM
bittermelon
Mar 27, 2008 03:46 AM
S.K.
May 4, 2005 04:44 PM
