Air shocks for 2013
Old Oct 15, 2020 | 09:14 AM
over40pirate's Avatar
Air shocks for 2013
Looks like Monroe discontinued rear air shocks for the fit.
Whats the alternative for towing?
Old Oct 15, 2020 | 10:18 AM
Bassguitarist1985's Avatar
The MA809s, but requires a small hub spacer for the air fitting to clear the tire.I did an entire writeup for my GK, but it will be a similar install for the 2nd gen
Old Oct 15, 2020 | 11:05 AM
Where can I view the write up?
any idea what max tongue weight with orig shocks/springs?
Old Oct 17, 2020 | 10:43 PM
Its on my 2017 thread. 200lbs max tongue weight for the class I hitch
Old Oct 17, 2020 | 11:49 PM
Fit towing
In your 2017 thread you mention air shocks needed and 200# max tongue weight. I was wondering about tongue weight with orig. Springs and shocks.
Old Oct 19, 2020 | 12:28 AM
Same limits apply. Air shocks simply help carry the load better.
Old Oct 19, 2020 | 07:44 AM
"carry the load better". By increasing capacity, by preventing springs from bottoming out. Is my experience y sing t h em. What do you mean by it?
Old Oct 19, 2020 | 04:56 PM
air shocks do not increase capacity, just helps carry the load better as in the springs not riding on the bump stops. If they were without air shocks, your tongue weight is too heavy.
Old Oct 19, 2020 | 05:13 PM
not sure why I'm having trouble with this!
your saying tongue wt max is 200# with or without air shocks. But without air shocks springs will be on bump stops..
I think max tongue weight without air shocks is an amount where the springs aren't near the bump stops. Which would be below 200#.
Old Oct 20, 2020 | 10:44 PM
Yes max 200lbs tongue weight. Car can only handle a class I hitch. Not saying 200 pounds will weigh the rear to the bump stops, but it will be close. You need air shocks to compensate for that. Either air shocks or air bags inside the springs will do the job. While air shocks/bags are not required, they are highly recommended!
blanka98
Jun 12, 2014 03:41 PM
linnboi
Dec 2, 2012 12:19 AM
DaveFL
May 25, 2012 11:44 AM
Kato
Oct 6, 2010 01:28 PM
Perrenoud Fit
Apr 19, 2010 07:31 PM
