How much strength is 44.1 lbf for the e-brake?
Old Nov 26, 2020 | 04:51 PM
StGemma's Avatar
Changed my drum brakes recently, and after putting everything together the service manual says to adjust the parking brake. If I am understanding this correctly, it says there should be 5 to 7 clicks to fully apply the parking brake, which equates to using 44.1 lbf.
My question is: how do I know I am using 44.1 lbf when pulling up on the e-brake lever? I mean, if I pull up hard enough I can get it to nine clicks, maybe a couple more if I really pull up hard enough.
Thanks!
Old Nov 26, 2020 | 06:23 PM
Ben Pierce's Avatar
Thanks!
Adjust it then spin the wheel with the tire on. Should be some light drag.
Old Nov 26, 2020 | 07:18 PM
StGemma's Avatar
Adjust it, then pull the e-brake up 5 to 7 clicks, then spin?
Old Nov 26, 2020 | 07:25 PM
Ben Pierce's Avatar
Yeah. Pull the handle up and release a few times to equalize. After adjustment. Then check for drag.
The more drag you get the tighter the e brake handle will be.
Old Nov 27, 2020 | 10:11 AM
Fiting's Avatar
Also check the wheels spin without drag when the e-brake is off.
Old Nov 27, 2020 | 09:45 PM
StGemma's Avatar
Awesome. Thanks for the info, gents.
nomenclator
Nov 2, 2023 08:36 PM
cooper58
Feb 6, 2018 07:22 PM
BklynFit07
Nov 29, 2017 04:17 AM
dbcmaster
Apr 17, 2008 06:39 AM
doctordoom
Oct 17, 2007 03:34 PM
