Lighter weight tires for the Honda Fit (GD, GE, GK)
Old Jan 3, 2021 | 08:32 AM
hmarkop's Avatar
Obviously tire weight isn't the only criteria when choosing a tire but for a car as small as the fit and as light as the Fit, the tire's unsprung weight can be felt especially if you choose a 20 lb. wider tire.
These below are lighter options ranging from 14 to 15 lbs.
Combined with a set of lightweight Konig Helium 15X6.5 wheels, you would effectively reduce unsprung weight at each corner by 10 lbs.
Altimax RT43
185/60R15 84T
Net Weight
15.23
Measured Rim Width
5.50
Section Width
7.4
Tread Width
6.66
Overall Diameter
23.7
Altimax RT43
185/65R15 88T
Net Weight
15.884
Measured Rim Width
5.50
Section Width
7.4
Tread Width
6.66
Overall Diameter
24.5
Conti TrueContact Tour
175/65R15 84H
Net Weight
14.69
Measured Rim Width
5.00
Section Width
7.0
Tread Width
7.39
Overall Diameter
23.96
Altimax RT43
175/65R15 84H
Net Weight
14.6
Measured Rim Width
5.00
Section Width
7.2
Overall Diameter
24.0
Kinergy ST H735
185/60R15 84T
Net Weight
15.2
Measured Rim Width
5.50
Section Width
8.0
Tread Width
5.8
Overall Diameter
23.6
GOODYEAR
Assurance All-Season
Net Weight
15.01
Measured Rim Width
5.50
Section Width
7.4
Tread Width
6.8
Overall Diameter
24.5
Old Jan 3, 2021 | 08:33 AM
hmarkop's Avatar
I should say that the source for this information was gathered from tireamerica.com (and crosss referenced with Tirerack.com )
These tires are all rated as average to above average in the reviews.
In my case, dry traction is the single most important criteria. I don't do much snow driving, and I'm extra careful regardless.
Myxalplyx
Jul 2, 2014 07:41 PM
mahout
Apr 27, 2010 08:30 PM
JoeF
Aug 6, 2009 06:33 PM
YeeFit
Jun 14, 2007 07:04 PM
Charles Lasitter
May 4, 2005 04:44 PM
