K24/K20 Swap
K24/K20 Swap
I am looking to do a K24/K20 swap in my Gd1 Fit in August. I have everything bought. But someone told me it's a nightmare to change from automatic to manual. Is this correct?
Also what speedometer clocks do you use, when you do the change?
I have swapped engines with my civics that I own. This would be my first engine swap with a Honda Fit.
Ideally, I wanted to import one from Japan, but one came up for sale in the colour white and with the bodykit I was looking for, so I bought it.
Nioce, good luck with the build. I am thinking about doing it in the future. K24 fits in gk5 apparently without any cutting of the frame rails.
It has been YEARS and a shop did my swap for me. From what I remember You would need the ECU for a manual fit and Harness,. I got around this by using a stand alone and a racepack. You of course need the clutch pedal and all the little things that go alone with that. The biggest issue I remember was the Trans mount is different between the Auto and Manual. Shop had to make a trans mount for my car.
Fitlexander
13
Nov 23, 2019 09:02 PM
