K24/K20 Swap
Old Feb 26, 2021 | 09:12 AM
ShinjirouK24's Avatar
K24/K20 Swap
I am looking to do a K24/K20 swap in my Gd1 Fit in August. I have everything bought. But someone told me it's a nightmare to change from automatic to manual. Is this correct?
Also what speedometer clocks do you use, when you do the change?
Old Feb 26, 2021 | 10:08 PM
RD36's Avatar
Start with a manual would have been easier. Have you swapped engines before?
Old Mar 1, 2021 | 02:57 PM
I have swapped engines with my civics that I own. This would be my first engine swap with a Honda Fit.
Ideally, I wanted to import one from Japan, but one came up for sale in the colour white and with the bodykit I was looking for, so I bought it.
Old Mar 1, 2021 | 10:09 PM
RD36's Avatar
Nioce, good luck with the build. I am thinking about doing it in the future. K24 fits in gk5 apparently without any cutting of the frame rails.
Old Mar 26, 2021 | 08:25 PM
MNfit's Avatar
It has been YEARS and a shop did my swap for me. From what I remember You would need the ECU for a manual fit and Harness,. I got around this by using a stand alone and a racepack. You of course need the clutch pedal and all the little things that go alone with that. The biggest issue I remember was the Trans mount is different between the Auto and Manual. Shop had to make a trans mount for my car.
Fitlexander
13
Nov 23, 2019 09:02 PM
EnticedByTiffany
Dec 18, 2013 01:34 AM
porkchop
Feb 19, 2009 04:14 PM
Bukwheat
Sep 25, 2008 07:02 PM
j5ive
May 21, 2007 07:12 PM
