Streaking wipers - what to do?
Hello,
I have 1st gen jazz and there is annoying things happening for a long time. I have streaking wipers. Actually only the drivers side wiper is streaking, but only on the way down. Drivers wiper cleans the window okay until it comes all the way to the upper position and then on the way down it starts streaking and leaves a streak straight at my sight of line. It's super annoying and happens most of the time if it's raining slowly or the windshield is not wet.
I bought new high quality wipers. I tried cleaning windshield with windows cleaner. I tried cleaning wipers with wd-40 - read that it helps, but nothing actually helped.
Could it be that windshield needs to be polished? Or the wiper motor is malfunctioning or needs to be tighten up?
I cleaned the windshield with windows cleaner. Nothing.
Maybe you tried rain-x?
If cleaning the glass doesn't help, you could also check if the wiper arm comes off the glass smoothly and the spring pushes it firmly. Had this happen on another car where the rear wiper would do almost nothing, turned out there was some rust in the hinge and spring that prevented it from begin pushed firmly against the glass.
shawnshank
Oct 19, 2013 04:45 AM
