rear bumper applique and applying it questions
Old Dec 16, 2006 | 12:56 PM
ashsblrsxtrg2006's Avatar
my sport doesnt come with it and i want to get one later. does anybody know the cost of one and if i can do it myself?
Old Dec 16, 2006 | 02:31 PM
rick@honda's Avatar
I have one on my ride, installed myself. Just make sure the surface is clean and mask tape it after for few hours after stuck on. If I rememebr it cost around $ 60 plus CDN. Very Happy with the result ..got to have it .
Good Luck.
Old Dec 16, 2006 | 06:44 PM
wat do you mean mask tape it? you masked taped the applique on?
Old Dec 16, 2006 | 08:32 PM
rick@honda's Avatar
I meant masking tape, just to make sure it sticks well on and dry before removing the masking tape off. It also comes with instructions.
Old Dec 17, 2006 | 03:25 AM
Fit of RAGE's Avatar
Hey, is this Rick from Richmond Honda?
Old Dec 17, 2006 | 08:22 AM
applique on your car
ive been looking around at the rear bumper applique for my fit and the instructions says to mark on the car with a pen for reference points. i saw a demonstration video on it too. is it safe to write on your car? how bout with a permenant marker? wat kind of pen should i use if i do?
Old Dec 17, 2006 | 08:55 AM
FitSport's Avatar
non perminate marker for marking...Use the dry erase type for bulliten boards...Or you can eye it and still be ok....
Old Dec 17, 2006 | 08:59 AM
FITforKRUG's Avatar
very good instructions came with the kit and I had no problem doing it may self. Still looks good after a year.
oh thanx a lot. woulda sucked if i marked it with permanent marker then
Old Dec 17, 2006 | 09:02 AM
im a newbie when it comes with trimming since the fit is my first car dont wanna mess it up. but ill give it a try. hopefully i dont mess up my car too bad
Old Dec 17, 2006 | 10:23 AM
rick@honda's Avatar
Yup, is me..
Old Jul 2, 2007 | 07:22 PM
arush19's Avatar
I just installed my bumper applique using the included instructions with a couple of modifications suggested by the dealer tech.
#1. Instead of completely removing the center guide strip from the adhesive, I shifted it 1/4" to expose a smaller patch. This way if you need to make adjustments only a small patch needs to be peeled off the bumper.
#2. I used masking tape on the bumper and marked it with felt-tip pen. This way you don't actually write on the bumper in case you use the wrong pen. Obviously, remove the masking tape before the applique goes over it.
fit2bowner
Feb 12, 2013 04:43 PM
txmatt
Sep 20, 2008 09:55 PM
FitPilot
Aug 29, 2008 02:27 PM
Luichenwai
Apr 14, 2007 11:05 AM
sirgolf82
Jul 17, 2006 12:04 PM
