Sponsored by:
Sponsored by: CARiD
How much does it cost to modify a car?
Old May 24, 2021 | 12:00 AM
MaXpeedingRods's Avatar
Former Vendor
Imagine that, you buy a bare car for 20 dollars which just can run. Of course, that is not enough. Then you change the rechargeable battery: 35 dollars, with a charger, 35 dollars, and a discharger, 20 dollars to let the nickel-chromium batteries maintain the best performance. Then you need to toss the motor. The original white-skin motor without torque has no advantages other than low power consumption. So starting from Silver Speedmaster, 20 dollars, Gold Speedmaster, 25 dollars, all the way to Jaguar motor 55 dollars found that the current of this motor is quite large, after running two laps, the conductive sheet is very hot, let's change the gold-plated one! 15 dollars. Now that the power system is almost solved, You start with the transmission system. The axles need to be carburized and hardened, 20 dollars. The oil-bearing bearings should also be replaced with ball-shaped, 40 dollars. The chassis should also be strengthened. Buy a few for the leading and phoenix guide wheels. Set the match, and then figure out the best match. The small 100 dollars was spent again until you installed the car and got on the track. The result was still unsatisfactory. You realize that the masters circumvent the motor by themselves. So you change everything from the rotor, coil, strong magnet, motor housing, and brushes, 200 dollars. Now you have a car. Now that you have much equipment, you need a whole set of shunting tools and toolbox, 68 dollars again. That is why car modification costs so much. Original from: https://www.zhihu.com/question/31122...swer/664107400
Lots of people are keen on modifying cars, but it is very expensive, but if you are particularly rich, I said nothing.
Have you ever bothered by this problem? how do you solve this problem, and how much did you spend on modifying the car?
Old May 24, 2021 | 10:22 AM
NWCH's Avatar
What are you even talking about?
valk97
164
Jan 9, 2025 05:06 PM
Owl
May 12, 2016 12:49 PM
Roger_PTY
Aug 25, 2012 12:49 PM
lilaznphatboy
May 7, 2009 04:26 AM
&REY
Oct 6, 2007 05:17 PM
