CVTF vs HCF-2 what should i use?
Old Jan 16, 2022 | 11:43 AM
maggieleung's Avatar
hi friends,
May i know what of the difference of CVTF vs HCF-2 ?
My car is Honda Jazz i-vtec exl cvt, CVTF vs HCF-2 what should i use?
thank you for your help.
Old Jan 16, 2022 | 07:01 PM
Pyts's Avatar
CVTF is any Constant Velocity Transmission fluid (perhaps you are referencing Nissan's CVT fluid, sold as "CVTF") while HCF-2 is Honda's own second generation CVT fluid.
I would recommend using Honda's CVT fluid, HCF-2, if it is listed in your owner's manual as the correct fluid for your CVT transmission. Alternatively, you can call the parts department at a Honda dealership to confirm the correct fluid. Sometimes their recommendations change.
Old Jan 19, 2022 | 06:19 PM
Thank you for your information.
Old Jan 21, 2022 | 04:03 AM
Hootie's Avatar
You're supposed to be using the older Honda CVT-1 which is more commonly known as "Honda CVT".
HCF-2 is formulated for the third generation of Fit CVT transmissions and is NOT backwards compatible on the second gen Fit unless specified in the owner's manual.
It depends on market, the label for the US version may not be the same as other markets. More than likely, their second gen Fit/Jazz is NOT HCF-2 as it was being phased in when the GE was soon to be phased out.
PolUotson
Canada Fit Forums & Clubs
Jul 29, 2015 10:11 AM
jvolstad
Nov 5, 2010 07:57 PM
tonyd3773
Jul 4, 2008 10:48 AM
tonyd3773
Jun 28, 2008 02:16 PM
accordguyintake
Aug 27, 2007 08:50 AM
