Seach 12V
Old Apr 17, 2022 | 05:36 PM
marccollin's Avatar
Seach 12V
hi
i want to install keyless entry, so i search where to get 12 v.
i have a honda fit 2008 lx
Old Apr 17, 2022 | 09:10 PM
GinoLicious's Avatar
Part is no longer continued.
https://www.fitfreak.net/forums/1st-...ml#post1241268
Full wiring harness part number is listed there. It was legit plug and play when I installed in my 2007 Fit base model. Best bet now would be a wreckers for the harness.
Old Apr 18, 2022 | 08:11 PM
marccollin's Avatar
I took this kit:
Amazon Amazon
how do you know if my fit have pneumatic central locking system?
do you know if it's #1, 2, 3 or 4 for a hond fait 2008 lx?
I found this information
  • POWER LOCK WHITE/GREEN (TYPE B) in DRIVERS KICK PANEL or GCM, 40-Pin Plug, Pin 9, See NOTE #2
  • POWER UNLOCK WHITE/BLUE (TYPE B) in DRIVERS KICK PANEL or GCM, 40-Pin Plug, Pin 10, See NOTE #2
  • DOOR TRIGGER GREEN (-) (Drivers Door), PURPLE (-) (Passenger Door) Use both, See DIAGRAM in EACH KICK PANEL, or GCM, 20-Pin Plug, Pins 13 and 14 See NOTE #2
on this web site
2007-2008 Honda Fit Vehicle Wiring Chart and Diagram
fuse for door lock seem to be 28
https://fuse-box.info/honda/honda-fi...007-2008-fuses
Old Jan 28, 2023 | 08:38 PM
Erfola's Avatar
Same situation
Originally Posted by marccollin
I took this kit:
https://www.amazon.ca/gp/product/B08...?ie=UTF8&psc=1
on this web site
hello
i am in the exact same situation with the same kit and I was hoping you solved your question to help me I stay mine maybe ?
Old Jan 28, 2023 | 08:40 PM
marccollin's Avatar
i paid someone in mtl to install it...les than 30 minutes and everything worked fine
ricohman
Mar 16, 2021 11:12 AM
Bryancito
Oct 7, 2014 07:22 PM
doublemj
Nov 16, 2010 12:34 AM
cbvaren
Apr 21, 2010 08:50 PM
fiftypercent
Feb 26, 2009 02:51 AM
