A/C Button Switch Doesn't Work
Old May 6, 2022 | 02:56 PM
DadDadDad's Avatar
Talking A/C Button Switch Doesn't Work
Trying to trouble shoot why the AC button doesn't light up when I turn the AC on. When I turn on the AC, the idle speed increases, but the light in the switch doesn't come on. I was looking at the wiring diagram, and it says there is a DIODE in the Under Dash Fuse/Relay box. When I google for this part, I don't find anything. Does anyone know what this diode looks like, and where it is located in the fuse box?
Old May 6, 2022 | 06:53 PM
JDFit's Avatar
You can replace the button (part 80410-TK6-A01ZA) or just the LEDs in button.
Old May 6, 2022 | 07:11 PM
DadDadDad's Avatar
In-line diode vs led in button
The wiring diagram shows a DIODE and is labeled as being located in the cabin fuse box. Do you know where in the fuse box it is located?
Old May 6, 2022 | 08:52 PM
JDFit's Avatar
Below and to the left of the steering wheel. Although it doesn't sound like a relay, the relays for AC are located behind the battery (need a skinny arm to get to it) There a 3 relay, two together are for the two fans and one in front is for the AC.
PC2K
Mar 24, 2022 11:03 AM
hydrocynus
Aug 17, 2020 04:35 PM
rflagg1408
Jun 24, 2014 08:04 AM
nojjon
Apr 30, 2013 06:55 PM
Moby8IIIIID
Dec 17, 2010 12:27 AM
