Help: 2015 Fit EX-L infotainment connectors?
Old Jan 1, 2023 | 12:10 PM
quintopia's Avatar
This is an image of the connectors to the radio/CD system I am replacing with a different device.
I have looked all over for someone selling a service manual for this model that explains what all these connections are to. I can tell which ones are power (there's a pinout diagram for that on this forum) and antenna and that's pretty much it. What I can't tell is which ones power and receive signal from the OEM backup camera or where the reverse signal comes in.
Could someone please label this image for me, or direct me to a labeled diagram online? If it helps, this unit is labeled model NR-241UH 45T05-T. The serial number from Mitsubishi is 945V0368.
Old Jan 1, 2023 | 04:10 PM
howarejew's Avatar
Old Oct 11, 2023 | 05:31 PM
medbh's Avatar
installing an aftermarket reverse camera
so i have exactly the same model ,any idea how to connect the rca yellow cable from the camera with the 24 pin socket (audio unit connector C ) the diagrame helped me alot so whenever i plug either groud or data cable to the 19th pin and select revers i get the display of reverse with lines but no camera image just black , any idea how do i proceed with the wiring.
Old Oct 30, 2024 | 10:09 AM
jgills240's Avatar
Post What I've Been Looking For!
I reworked the images into the attached PDF for easy printing.
File Type: pdf
Darlwy
Jan 9, 2019 10:33 PM
Spunkmire
Jun 5, 2016 02:43 AM
xancholy
Dec 8, 2014 04:10 PM
Ricksnewfit
Sep 15, 2014 11:09 AM
15/SILVER/EXL
Aug 10, 2014 02:35 AM
