ticking from engine
Old Mar 27, 2023 | 09:48 PM
jmforem's Avatar
ticking from engine
I have a 2009 Sport, manual transmission. 136K miles.
A ticking sound just recently started. As best I can tell it is coming from the top of the engine.
It does not matter if engine is hot or cold. It is a steady, but irregular ticking. It does track with engine speed.
I've attached a video. I attached it in two formats in case there are problems playing one of them.
The video is not very informative, but hopefully the audio will be usefull.
Any ideas what this could be?
File Type: mpg
File Type: avi
Old Mar 28, 2023 | 03:56 AM
Erbid's Avatar
Plugs is a popular one.
You may have caught a loose plug before it ejects or cooks a coil. If it could be coming from the plug/coil area, snug your plugs.
Old Mar 29, 2023 | 09:35 AM
GAFIT's Avatar
Valve adjustment was due at 90k miles. If it's not been done, get a set of spark plugs and do the valve adjustment very soon. The ticking could either be a loose spark plug (which will eject itself and cause damage if not done) or out of spec valve clearance (which can cause damage to the valve seats).
Old Mar 29, 2023 | 12:44 PM
jmforem's Avatar
Thank you GAFIT and Erbid for your feedback. Very helpful.
Old Jul 17, 2023 | 08:19 PM
jmforem's Avatar
A follow-up to my post-
I had the valves checked. They did need adjusting. Saw a noticable improvement in MPG after valves were adjusted.
The ticking sound was not the valves, not a loose plug. It is actually from the serpentine belt idler pully bearings- dry bearings. Easily diagnosed using stethascope.
Old Jul 17, 2023 | 08:26 PM
GAFIT's Avatar
Thanks for the follow up!
Old Jul 18, 2023 | 10:42 AM
Mister Coffee's Avatar
@jmforem Thanks for following up.
@GAFIT Ticking from a loose spark plug? I have to scratch my head on this diagnosis. I suppose that it is possible, right before the plug blows out entirely. All due respect, of course. You know I'm one of your fans, GAFIT.
Old Jul 18, 2023 | 11:06 AM
GAFIT's Avatar
Ticking may not be the best way to describe it, but just before it blows you can hear the exhaust blowing past the plug. My friend said his car started "ticking" and then lost power when it ejected a plug at highway speeds.
Blackfitge2
Jan 3, 2024 02:39 PM
RedFitBoken
Jan 21, 2023 03:10 PM
SLIPNFIT
Jun 8, 2021 04:34 PM
Spooling
Jul 21, 2009 10:54 PM
tonyd3773
Feb 7, 2008 11:43 PM
