Driver Power Windows dont work after replacement
Old Apr 29, 2023 | 06:02 PM
ZachyMan119's Avatar
I've got a 2008 Honda Fit and recently the driver power window stopped working entirely, so as normal, I replaced the switch 2 times (was the original one) and found that didn't fix it, so I replaced the Motor/Regulator 2 times and that still didn't fix it. I went then to the fuses and used a fuse tester and found that all power window fuses are still in working order, and finally I replaced the relay 1 time. I'm in the process of checking the continuity of the wires. All the switches still can operate the other 3 windows just fine. I've checked if there is power to the motor and there is. Any ideas are welcome.
Edit: Found that the wire was broken where the door meets the body.
Old Jun 29, 2023 | 11:25 AM
dosbirn's Avatar
Glad you found the problem! I'll be working on my PS front switch soon. I sure hope it's only the switch.
rocksnap
Jul 27, 2024 01:59 PM
Cedbomb
Aug 19, 2022 03:11 PM
Cordizzle4life
Feb 10, 2019 09:58 AM
aceofspeeds
Feb 22, 2013 01:11 PM
Daisy K.
Sep 5, 2005 10:32 PM
