GK5 Front Undertrays or Other Aerodynamic Parts
Old Aug 1, 2023 | 11:45 PM
2015LXFIT's Avatar
Hi there, I'm looking to gauge interest in better designed undertrays for the GK5 series Honda Fit front undertray. My OEM piece tore off due to snow, I replaced it with an aftermarket one but that was garbage and is now dragging... Fun... Taking into account the aerodynamic improvements of undertrays (some as high as 15+% mpg), I'll likely be making either an aluminum or plastic/polymer front undertray with improved attachment design (if possible), as well as other possible requests as well. Thanks for stopping by. (Also any electronics improvements I may be interested in as well) Cheers.
Old Aug 2, 2023 | 09:26 AM
NWCH's Avatar
Except there is nothing wrong with the stock plastic under-tray. Just replace it if you want to use it. Also if you upgrade to a metal panel then you will need to upgrdade your fasteners. The stock plastic clips will not hold a large heavy under-tray.
I would just replace it with the stock parts. Upgrading that for any reason at all is overkill.
Skyboi
Feb 8, 2023 09:43 AM
SLIPNFIT
Apr 24, 2022 03:56 PM
ccklouis
3rd Generation GK Specific Suspension & Brakes Sub-Forum
14
Aug 23, 2020 04:15 AM
PHNTMONE
Feb 18, 2015 01:43 PM
Jelani
Jan 8, 2015 08:26 AM
