Coolant question
Old Nov 16, 2023 | 12:41 AM
SLIPNFIT's Avatar
Coolant question
How often are you guys having to top off your coolant? Just checked my coolant level in my reserve tank on a cold engine and it was below the minimum level. I topped it off to max(just a lil over) and was curious to know how many miles you guys top it off on average? I had to change the thermostat and drain and refill the coolant like 8 months ago and have probably put on 20k miles running a tune with ktuner. I'm wondering if the tune is making it drink the coolant faster than normal. Oil looks good and no signs of a head gasket problem. Thanks Fit Freaks 🫡
Old Nov 16, 2023 | 09:39 AM
woof's Avatar
Pretty much never. However my fluid was changed two years ago and for a couple months afterwards I had to repetitively top it off with small amounts as air pockets gradually worked their way out. I don't drive a lot so that probably dragged out the process.
Old Nov 16, 2023 | 01:00 PM
Drew21's Avatar
Agreed with previous poster. Maybe you thought you were full after your change 8 months ago but weren't. How often do you look at the reservoir? Assuming you were full 8 months ago you should be full today. The cooling system is a closed loop.
Kiju
Sep 4, 2022 11:24 AM
jessepinho
Nov 19, 2021 04:28 PM
doctor J
Jan 23, 2019 03:02 PM
Kishore
Jul 3, 2011 11:42 AM
Batman
Dec 1, 2007 05:54 PM
