Broken ABS sensor
Old Dec 10, 2023 | 04:00 PM
Sunflow99's Avatar
Broken ABS sensor
So I replaced my rear wheel hub assembly on my 2015 Fit EX today, but when I went to replace what I assume is the ABS sensor that attaches to the hub via a screw, the plastic piece broke. So now the ABS light is one, tire sensor light is on. I can’t seem to find the right part to fix this, can anyone help?
Old Dec 10, 2023 | 05:12 PM
GrE8_Fit's Avatar
It seems to be a very common problem. If you are able to remove all the pieces of the old sensor you should be able to replace it with a new one. If part of the sensor broke off in the hub you may have to drill it out.
https://www.rockauto.com/en/catalog/...ed+sensor,1912
Old Dec 10, 2023 | 07:14 PM
Sunflow99's Avatar
Thank you for this. All the pieces are there, cause i screwed it into the hub, and then the plastic broke. I've seen the problems where people are having to drill out where the sensor comes into the knuckle, but this is a totally different set up, the wires come straight through and attached to the hub. I can't find anything about it anywhere
Old Dec 10, 2023 | 07:41 PM
Sunflow99's Avatar
Where the circle is is what broke today
jdDC
Dec 30, 2015 02:52 PM
GregDavis11009
Oct 28, 2015 08:11 PM
ThEvil0nE
Aug 1, 2010 10:16 AM
glen62
Jul 1, 2010 10:28 PM
RandomKoko
Jan 23, 2009 04:51 AM
